Hi all. Havent been here for awhile, so I thought id share some good news. After numerious problems with my car, we finally found some reliablity and came out class B winner for the weekend, while almost everyone else had dramas. The only problem we had was a lack of power, the car is tuned with 300kws, but some of that seems to have gone awol! Did find were some of it was going, out though a loose bolt on the the dump pipe, but once that was done up, it still didnt feel super quick like it did before. We have had the head off, so maybe we didnt get the cams spot on, so it will get tuned before we race again.
managed a fastest lap of 61.6 for the weekend, but should of been able to do 60's if all the power was there.
ive uploaded a couple of video to youface.
My link
My link
Looking good man, a couple of guys from SAU were up there on Sunday (myself included) and it turned out to be an awesome day.
61.6 is a good solid time, but 60's at symmons would be a great base time ;)
so says you... Mr 70s :P
You're such a super troll Mr. Nowell, what's your best time around symmons again? Oh yeah, that's right... :P
I've never even driven symmons. Just commenting on times in regards to the competition like every other joker out here, not comparing them to anything I've even experienced ;)
You should be stoked just to have finished with the problems that everyone else had.
When are you coming up for some laps trollbermerc?
It was crazy watching the race on Sunday, half the field disappeared by the end of the race :P
I'm pretty sure he's coming up for some quarter laps (drifting) this weekend :)
To everyone anyone that didn't run this event and could’ve... sorry, but you seriously missed out!
I wasn't that fussed about running at the V8s in the past, but with my car finally up and running and with some tyres, pads and rotors left-over from Rally Tas, at the very last minute I thought why no let’s do it.
For me it was such a cruisey reintroduction in to circuit racing with zero pressure... so much so I missed qualifying due to a minor (clutch master cylinder) issue, and instead of fixing it straight away we watched qualifying then sorted it!
It was fun getting the hang of the 'new' car on the track (particularly off the back of the grid in race one!), re-understanding tyre performance checking out cooling temperates etc... and generally enjoying some dicing with a bunch of top guys and it was pretty cool just being part of the V8 circus.
One of the best things about the Invitationals was the race lengths. I always enjoyed the longer races back in 2004 when I last did a full circuit season in the R32 with 12 and 15 lap races.
Being out there for 12 laps at the V8s was great fun. Five laps like usual TSS rounds are just too short, seven fine, ten great... 12 or 15 would be awesome again.
If you have a car able to compete and the V8SC offer the opportunity for this category to run again in 2013, don't give it a second though, just get amongst it!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
