  • Replies 191
I can do 6x of the injectors for $720 incl. delivery.
They are all flow matched.
Required extensions and plugs would be an extra $95 for all 6.
Hey,
I can do some SARD 800cc side feed (high impedance) injectors for $145/injector incl. delivery.
- Brendan
Hey mate after 650cc side feeds for SR20, not fussed on brand just want some prices cheers
Hey mate,
Side feed injectors are not common these days, I can do any choice of 540cc, 550cc or 800cc SARD ones for $590 incl. delivery (Express) for the 4x.
- Brendan
after a price on a set of 1000cc and 2000cc injectors for rb26
Hey,
I would go with EV 14's in the 1000cc size, they are a popular RB26 choice with us.
The injectors including extensions and plugs would be $630 incl. delivery (Express)
For the other ones you can't go wrong with the BOSCH 2200cc ones, I can do 6x of them with all extensions and plugs to suit for $780 incl. delivery (Express).
Let me know what you decide, these are very popular injectors and great deals on them as well.
- Brendan
How much for 6x top feed ID1000cc injectors for r32 gtr
Hi,
6x ID1000cc (BOSCH EV14's) with extensions and plugs to suit GTR would be $600 incl. delivery
- Brendan
Hey,
- Brendan
hey mate can i get a set of the BOSCH 2200cc ones with all extensions and plugs to suit for $780 incl. delivery (Express) pm sent
Sure thing mate, I'll PM you details now.
Hey,
I can do 4x BOSCH EV14's 1000cc (flow matched) including extensions and plugs to suit for $430 incl. delivery or the 2200cc short's for $580 incl. delivery again with all extensions and plugs.
- Brendan
Hey mate,
What's your largest side feed injector? And price?
After 6
Thanks
Hi,
I can do 6x SARD 800cc side feed injectors for $880 incl. delivery.
I can supply plugs as well if required.
Cheers,
Brendan
  • 2 months later...
Hey mate how much for a set 875cc for r33 gtst
Hey,
Are you using the standard side feed injectors? - only option would be SARD one's then.
- Brendan
I would like to get some injectors to suit my R34 GT-T RB25 NEO and would like to go with the injector dynamics.
Can you supply these as a direct fit with whatever plugs and adapters etc are necassary?
Please get me a price for a drop in solution using injector dynamics id850 or id1000s.
Also it is my understanding that id1000s are bosch ev14s, but injector dynamics flow match them and provide a flow report with each set of injectors. From what I have read they also mill downs the ends and modify them in some way. Can you confirm this?
Thanks
Edited by vkadam
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
