Come on man , I was in shocks at the moment n I just need help bro , don't have to be angry about it ya, when I start e car, nth seams to work the radio not working the head lights not working , nth is working, it's like it's dead, was thinking of changing e battery n see how it goes bro
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
