Hi all.
Just gave my 93 R33 a run at full throttle from about 60 kmph and it started "popping"
93 R33 gts25t
Only mod is turbo back full exhaust .
Standard boost, no pod.
The popping sounds the same as when it changes gear under heavy acceleration. It started around 5-6000 rpm and lost all power while it was happening.
Could it be?
A, fuel cut.
B, Detonation.
C, Faulty wast gate / Std Bov
I would love some opinions and to hear from anyone who has had this issue and fixed it.
Thanks all.
Hi all.
93 R33 gts25t
Could it be?
A, fuel cut.
B, Detonation.
Thanks all.
Also it didnt happen anywhere near as much if I accelerated slowly to full throttle still did a couple of pops but held its power.
Yup you got it. Exactly the same.
Ill start working on the electrical side as soon as i have done the fuel pump.
I changed the filter and it helped a little.
Its going to go something like this,
Fuel Pump, injectors and the things that they include..
then ignition side coil pack, leads plugs.
Im not looking to make it a rocket ship it will just be nice to have it running at full capacity.. (foot to floor no issues)
Check your FPR, pull the vac line off it and have a sniff.. If it smells like fuel, then it's a faulty FPR.
I had the same problem as you, but my issue was contaminated fuel..
Could also be a faulty pump.
By the way, do you have a larger pump ? Say a 040 ? If so, they hate 1/4 tanks of fuel lol (well mine does anyway) and it surges on boost..
Firstly im going to get the std pump to 12 v so its running at full pressure and see if that makes a difference. After that ill fit the 040 as the DIY topic explains.
I take it "FPR" is Fuel Pump Return line?or something to that description?? The one that runs from the engine back to the tank past the filter??
  • 3 weeks later...
had similar problem after fitting 3" hi flow cat. changed plugs to iridium and reduced gap slightly 0.9 mm i think, smaller gap better when combustion pressures are higher as fuel harder to ignite. gave coil packs a good clean as there was carbon around them. ran fine then. drew
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
