33 gtst - clutch and full exhaust (bellmouth)
Had issues for a while when I fill up tank with fuel and start the car it won't idle correctly and hunts (sometimes stalls)
This issue I was always a bit whatever about it. Hit the throttle and she settles ok.
Major concern is:
I have had a very intermittent issue where the exhaust will pop when I decelerate with no throttle and then touch the throttle it will pop no matter how many times I go on an off throttle. Sometimes it will get so bad it will pop whilst decelerating down revs without touching the throttle.
Through the revs doesn't miss a beat.
Did it with 2 different motors in it. (blew motor) Only things that remained on change of engine was afm, tps, coils and loom. (fuel pump of course)
Cas, plugs, fpr, injectors all changed.
I got consult to find O2 sensor sitting at .3 when cold then when at temp sits around .1-.2V. Had a spare sitting around so tried that and it just read 0.0-0.15V. So I Bought O2 sensor and found readings Fluctuated from .28-.80V. Which a mates car also did. Got better fuel consumption of course.
Car still popped intermittently.
Tested for vac leak and all good.
Tested tps voltage and all good.
Also I originally had exhaust studs snapped so gathered that would cause popping. Changed all studs and gasket. Still popped intermittently.
It was very intermittent so hard to diagnose but of course now I am in QLD on holidays it is doing it a lot more then normal.
I have found that when I'm low on fuel it doesn't pop at all no matter how much I cruise or thrash it. I pull into servo and put fuel in and I pull out to check if it pops and it does.
So I am thinking fuel pump but why or can u guys think of something else?
Sorry for massive read but wanted to give as much info as possible.
I also understand if u all are not in the mood to think as it is Easter and u may be drunk or hungover.
https://www.sau.com.au/forums/topic/397196-exhaust-popping-on-decel-bad/
Also check tps setting.
Did u keep the charcoal canister or remove it? If u removed it wat did u do with the lines? I had a mate route his breather line to the inlet manifold and wondered why it was running rich on decel and accell
Stock bov not blocked.
Exhaust wrap isn't needed for flames lol. It's stock and people think its off tap cause it blows flames.
Charcoal canister lines were put on as they were but will gO over them in the morning.
Checked it couple times as that's what everyone thought it would be and didn't believe I checked it right. It is set at .43v and reads normal on consult when issue is happening.
I'm going to get stuck into it now and see how I go.
One way to check whether or not its the TPS is to turn the ignition off whilst on decel and see if it makes any difference. If everythings working as it should it shouldn't make any difference. Just make sure the motors hot first
Yea that's still the same with ignition off.
I have vented charcoal canister to Atmosphere and it hasn't popped and carried on today.
Will hook canister back up tonight and see if it pops (of it does) then i will undo it to see if it fixs it.
Also found fuel filler fitting loose which is why fuel leaked last DECA.
Just did manifold gasket as I had 8 snapped studs lol. All new genuine parts. Reused gasket to exhaust which was fine.
When it was popping I thought this was due to fix it for sure but didn't :(
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
