g'day
i have an rb25det head that has bin modified to go onto an rb30 block.
i have decided to go back to an rb25 bottom end as the 30 one is stuffed and i scored a free rb25det bottom end.
the vct oil gallery on the head has bin welded up and i have drilled out the copper bung as per the rb30det conversion thread.
what do i have to do to put the head back on a 25 bottom end? i dont realy want to drill the oil gallery on the head back out...
cheers
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
