Are neons illegal?
If they are in the front grill (the globe isnt showing), and its red?
i heard from somewhere that red is illegal, but green n blue arent?
can anyone help me with this
thanks
ps, if you are going to say neons are shit, dun post, I cant be bother reading it..
when mine were... um - inspected, nothing was said about the colour, just no flashing, and make sure the globe can't be seen.
Ive tried driving around with all three colours at one time or another, and so far no sticker ! so im guesing they're ok...
also ref. this thread... http://www.skylinesaustralia.com/forums/sh...ead.php?t=38868
hope this clears things up
Phil
https://www.sau.com.au/forums/topic/39795-neons/#findComment-812783
Are neons illegal?
thanks
I've recently been involved in a yellow sticker incident involving neons, so I can quote first hand what is and isn't allowed.
The law according to a Dept of Transport vehicle inspector:
Neons are legal under the following conditions,
You must not be able to see the elements from a seated position in an ajacent vehicle, neons are not allowed to pulse or flash, you must not have a red neon facing forward, all other colors are acceptable, all colors including red are acceptable for the sides and rear, they must be adequatly secured and the elements shielded to avoid exposure to other drivers. You can drive around with them on.
The law according to some cops:
Yellow sticker every vehicle with neons as they are deemed a distraction to other drivers, you can't have them on whilst driving but static in a carpark is OK.
My personal suggestion is put em on the correct way, use them and know the law and your rights if you get pulled over, just remember though it could cause the cops to look for other defects on your car so keep it neat and legal.
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813144
no good comes from them....
you get more "rice boy" shit from trevs
more attention from cops
if your car is stock and you have neons thats just stupid
if your car is bombed, looks like the 2 fast 2 furious car (like danny's :D) then its ok because he is riced up on every other angle so the neons dont look outa place. :rofl:
all i can suggest is dont turn them on or off infront of a cop
because then they will say they are flashing, and if you are turning them off then the cops will think your guilty of something and pull you over... :(
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813352
ok, cos ive got a couple of blue ones like under the dash, on either side and i got a red one, in the front grill...u cant see the globe only the red light as you could say...so yer, hopefully, i wont be braggin over it, like hsowing them left right n centre, but the occasional should be ok..
thanks guys
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813611
if your car is bombed, looks like the 2 fast 2 furious car (like danny's ;)) then its ok because he is riced up on every other angle so the neons dont look outa place. :)
because then they will say they are flashing, and if you are turning them off then the cops will think your guilty of something and pull you over... :rofl:
funny thing is i see more commodores falcons and other trev crap with neons on them than jap cars so i dont know how they think WE are 'rice'
https://www.sau.com.au/forums/topic/39795-neons/#findComment-814667
thats true. have seen plenty of commodores with cheap and nasty neon installs.
:vomit:
I find this to be true also... and the ONLY thing worse than a cheap and crappy install is cheap and crappy neons - if they are so dull you can only see them when parked in the dark, why bother?
https://www.sau.com.au/forums/topic/39795-neons/#findComment-818632
BASSULA - Nice Work mate !! :D
looked at the iceled kits when i was buying, but they were just a little out of my range :(
Ended up with liteglo... only 8 colours, 1 at a time or cycling, but thinking of writing my own ROM for it...
for now though... :D ICELED
btw, Ill be up in the capital sometime in June - Should go cruisin...
Cheers,
Phil
https://www.sau.com.au/forums/topic/39795-neons/#findComment-823593
thnx phil,
If you want a in the flesh demo of the ICELED kit drop me a pm/e-mail when you are in perth. always willing to show it off a bit.. :D show ya that its not just a underbody kit.. :D
cheers
i might just do that... im a sucker for the *bling*... where'd you source them, if you don't mind me askin' ? was it a private import job, or does someone actually stock those things?
https://www.sau.com.au/forums/topic/39795-neons/#findComment-823620
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
