Are neons illegal?
If they are in the front grill (the globe isnt showing), and its red?
i heard from somewhere that red is illegal, but green n blue arent?
can anyone help me with this
thanks
ps, if you are going to say neons are shit, dun post, I cant be bother reading it..
when mine were... um - inspected, nothing was said about the colour, just no flashing, and make sure the globe can't be seen.
Ive tried driving around with all three colours at one time or another, and so far no sticker ! so im guesing they're ok...
also ref. this thread... http://www.skylinesaustralia.com/forums/sh...ead.php?t=38868
hope this clears things up
Phil
https://www.sau.com.au/forums/topic/39795-neons/#findComment-812783
Are neons illegal?
thanks
I've recently been involved in a yellow sticker incident involving neons, so I can quote first hand what is and isn't allowed.
The law according to a Dept of Transport vehicle inspector:
Neons are legal under the following conditions,
You must not be able to see the elements from a seated position in an ajacent vehicle, neons are not allowed to pulse or flash, you must not have a red neon facing forward, all other colors are acceptable, all colors including red are acceptable for the sides and rear, they must be adequatly secured and the elements shielded to avoid exposure to other drivers. You can drive around with them on.
The law according to some cops:
Yellow sticker every vehicle with neons as they are deemed a distraction to other drivers, you can't have them on whilst driving but static in a carpark is OK.
My personal suggestion is put em on the correct way, use them and know the law and your rights if you get pulled over, just remember though it could cause the cops to look for other defects on your car so keep it neat and legal.
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813144
no good comes from them....
you get more "rice boy" shit from trevs
more attention from cops
if your car is stock and you have neons thats just stupid
if your car is bombed, looks like the 2 fast 2 furious car (like danny's :D) then its ok because he is riced up on every other angle so the neons dont look outa place. :rofl:
all i can suggest is dont turn them on or off infront of a cop
because then they will say they are flashing, and if you are turning them off then the cops will think your guilty of something and pull you over... :(
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813352
ok, cos ive got a couple of blue ones like under the dash, on either side and i got a red one, in the front grill...u cant see the globe only the red light as you could say...so yer, hopefully, i wont be braggin over it, like hsowing them left right n centre, but the occasional should be ok..
thanks guys
https://www.sau.com.au/forums/topic/39795-neons/#findComment-813611
if your car is bombed, looks like the 2 fast 2 furious car (like danny's ;)) then its ok because he is riced up on every other angle so the neons dont look outa place. :)
because then they will say they are flashing, and if you are turning them off then the cops will think your guilty of something and pull you over... :rofl:
funny thing is i see more commodores falcons and other trev crap with neons on them than jap cars so i dont know how they think WE are 'rice'
https://www.sau.com.au/forums/topic/39795-neons/#findComment-814667
thats true. have seen plenty of commodores with cheap and nasty neon installs.
:vomit:
I find this to be true also... and the ONLY thing worse than a cheap and crappy install is cheap and crappy neons - if they are so dull you can only see them when parked in the dark, why bother?
https://www.sau.com.au/forums/topic/39795-neons/#findComment-818632
BASSULA - Nice Work mate !! :D
looked at the iceled kits when i was buying, but they were just a little out of my range :(
Ended up with liteglo... only 8 colours, 1 at a time or cycling, but thinking of writing my own ROM for it...
for now though... :D ICELED
btw, Ill be up in the capital sometime in June - Should go cruisin...
Cheers,
Phil
https://www.sau.com.au/forums/topic/39795-neons/#findComment-823593
thnx phil,
If you want a in the flesh demo of the ICELED kit drop me a pm/e-mail when you are in perth. always willing to show it off a bit.. :D show ya that its not just a underbody kit.. :D
cheers
i might just do that... im a sucker for the *bling*... where'd you source them, if you don't mind me askin' ? was it a private import job, or does someone actually stock those things?
https://www.sau.com.au/forums/topic/39795-neons/#findComment-823620
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
