Garage Cleanout R32 Gtr Leftover Parts And R31 Headlights
Well I've finally finished putting my GTR back together and gave the shed a cleanout the other day and it's time to get rid of the leftovers mostly standard parts I've replaced with aftermarket items but a few aftermarket bits that came on the car.
Nismo Gmax twin plate clutch pull type. Came with the car I didn't get enough time in the car to really test it out but it didn't seem to slip depending on how much you enjoy pulling out gearboxes I'd probably recommend a rebuild.
post-58307-0-54349600-1334829832_thumb.jpg post-58307-0-17991400-1334830557_thumb.jpg$300
Standard manifolds and dumps
post-58307-0-77605200-1334828618_thumb.jpg$40
Standard cam gears
post-58307-0-30934100-1334828728_thumb.jpg$40
Standard computer with chip I only know this cause I removed the cover and had a look. It has a cradle soldered in with a chip in it. Not sure of what it's got on the chip but the car went unusually hard before I took it off the road.
$120
Short shifter
post-58307-0-88279800-1334828580_thumb.jpg$50
Pod filters with elbows
post-58307-0-85566200-1334828680_thumb.jpg$75
R34 GTR Vspec2 Turbos I bought these off a member on here 2 years ago fitted them and drove the car for 3 days they had done 62,000kms when I bought them. They have .48 rears and .53 fronts and are ceramic wheels as far as I know. I have the serial numbers if anyone wants more info.
post-58307-0-85893200-1334828637_thumb.jpg$300
R32 GTR turbo x1 One of the old ones off the car when I bought it not sure of kms. .48 rear .42 front
post-58307-0-30295400-1334828662_thumb.jpg$50
Full aircon setup for GTR everything from the firewall forward inc pump/condenser etc might even have belt
$120
GTR injector resistor module I have cut the plug off of this but the wiring is straight forward 1 white wire 6 black
post-58307-0-66249800-1334828753_thumb.jpgOffers
Full set of stock GTR intake pipes inc the 2into1 blowoff valve return pipe
post-58307-0-83745000-1334829727_thumb.jpgOffers
Replacement coil pack plugs x4 I needed 2 had to buy 6
post-58307-0-62883000-1334830066_thumb.jpg$25
Stock thermo fan
post-58307-0-11145300-1334829748_thumb.jpgOffers
Stock boost control solenoid
post-58307-0-32367400-1334830082_thumb.jpgOffers
R31 series 3 headlights perfect condition
post-58307-0-28823900-1334828600_thumb.jpg$100
Jap spec yellow projector spotlights
post-58307-0-95503700-1334828706_thumb.jpg$40
Stickers 2x small 1xmed 1xlarge
post-58307-0-28572100-1334829678_thumb.jpg post-58307-0-14063200-1334829712_thumb.jpgOffers
Gearstick boot
post-58307-0-19460500-1334829792_thumb.jpgOffers
Speco 7mm slip on wheel spacers
post-58307-0-95115000-1334829812_thumb.jpgOffers
S13 adjustable camber tops Brand new I'll post pics tomorrow<p>$10
Edited by trustr32
S13 adjustable camber tops Brand new I'll post pics tomorrow<p>$100
Hey pipster sorry about that but I have obviously missed a 0 when I edited the post they're supposed to be $100 It has also deleted my mobile number so if anyone wants to txt me it's 0419176656 I'll get those pics up this arvo.
Pipster they fit the 31 strut tower but the threaded sleeves/ nuts they come with don't fit the thread on the top of the shocks. Well they didn't fit Monroe gt shocks anyway ji was going to get different ones machined but I sold the car before I got round to it. Sorry I've been slack I'll put pics tomorrow.
Hi stuart sorry I spent the day down home today and I get stuff all reception I'm headed to Kingston in the morning so I'll give you a call then.
Justin I bought them off eBay $50 a set with all the new metal plugs grommets and the actual plug housings.
Hey lad's some pictures I have been meaning to put up for a few days now.
Afew things are on hold for a few people and the short shifter is already sold to NISSANGTS
Stock intercooler pipes, A/C setup, stock mani's and pods with adapter elbows are on hold for jangles
S13 camber tops are on hold for pipster
Here's pics of the intercooler pipes layed out.
post-58307-0-07894900-1335083258_thumb.jpg post-58307-0-17936600-1335083299_thumb.jpg post-58307-0-77392300-1335083335_thumb.jpg
Pic's of the camber tops
And pics of the R32 GTR ecu it also has a link cable thats been put into it at some stage not sure what it's for exactly but it's got a jap sticker on it.
post-58307-0-09928100-1335083422_thumb.jpg post-58307-0-24061500-1335083463_thumb.jpg post-58307-0-06611200-1335083506_thumb.jpg post-58307-0-19617100-1335083548_thumb.jpg
A/c setup found out today that I must have ditched the 2 lines that run from the firewall to the condensor unit so looking for $90 now
  • 1 month later...
Hi mate,
Is the R32 GTR ECU stock (other than the link cable), and you know its working? Also how much?
I'm looking for one to put a nistune board in.
Cheers.
Na man it's got a cradle soldered in and I'm pretty sure it's an aftermarket chip in it. Came out of the car when it was running and went rather hard so not sure whats on the chip. Wanted $120 for it.
Cheers for the info (sorry I missed the text in your first post without the ecu pics).
Sounds like a good ecu but probably not worth cannibalising it for a nistune mod. Thanks anyway.
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
    • Yuh, but that one is NLA. There might be an equivalent, but I haven't looked.
    • If you hadn't bought a stand alone one already, nismo make a bolt on adjustable FPR https://www.efisolutions.com.au/nismo-fuel-pressure-regulator-sr-rb-s13-180sx-r32
    • I know and understand they are principally the same. They both cause lock under decel, but the 1.5 nomenclature implies "half" or less locking force, or it allows for more slip or a speed differential between both wheels. Right now the driving manners with the 2 way is pretty rough on transient to full off throttle in the backroads. In other words letting off the throttle too rough is not forgiving, great for drifting, tougher for controlled grip driving.      Yeah, I have watched that video a couple times, I am more so just looking for the confirmation that both part numbers offer the same ramp architecture and are just different settings from the factory.     38420-RSS15-B5  38420-RSS20-B5
