  • Replies 185
Posted Images
Ok I booked it for 15, Booked at 6:30 ITS Important we are there at 6 30! no later as they run it on a schedule to get more customers in etc with bookings.. So please time is of an essence.. Vorse And RBSCREAMER you guys are in!
Alright guys we will depart 1:20 SHARP! If your not there to bad, you come in the cinema's late :P And yes this includes a bit of seafood Tezzah!
Still think it might be a better idea to leave at 1pm sharp if we're taking Bells, will leave people some time to park / check out cars / buy tickets / popcorn / use the loo, etc before the session at 3pm. But your call Juz!
not sure what more you need braden (who i just realised i see every day on facebook)
meet half twelve like Jus said, depart 1pm to cinema which will finish in time for the japanese food dinner which we cant be late for, then everyone goes their separate ways..
you going to have that BOV for me by this sunday?
be good to finally meet some of you peeps and catch up with Eddie, Justin and Terry.
something to put in the GPS for the meet up place would be good though Jus, and yeah i was too lazy to check page 1 again :unsure:
:cheers: Patrick, will be good to catch up with u and make new friends. My cars at Croydon getting a Tune with Jim the legend. Was getting the car back today but Dyno blew up. LOL (maybe too powerful).Getting it back tomorrow.
If anyone does drop out of the Teppanyaki Dinner (after Bullitt), Maria will take their spot :)
Or if there's an extra available Justin, Maria might sit next to Genelle. :)
Ta
Looking forward to BULLITT one the iMax Screen eh?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
