  • Replies 185
Posted Images
Thanks, Oh yeah haha i remember the silver 33 behind me, Hows it goin sorry if i was holding you up. I cant work out how to get a profile pic up. I go to change it and it fails to upload.. Probably the web speed. Good to talk to others that love skylines as much as me hey. Ill definately be coming along for the next cruise to meet everyone.
Hey just out of curiosity, How much boost is this gtr running with the restrictors on exactly? Guage goes to 7 but it only makes it to the bar before 7. So about 5psi u think?
no idea re boost but there is a forced induction section on here that would have the answers though a few of the people who came last night are pretty technical and might know the answers..guise?
didnt hold me back ryan as you were way back, there were like 3 or 4 silver R33's lol, i was up the front leading the pack..like a baawwsss
(till i got lost)
:ph34r:
anyway new facebook profile is up and heres the shoddy gallery, CBF deleting the blurrys as yet
http://www.facebook.com/media/set/?set=a.114582825346134.16774.100003832519363&type=3
Why don't you change your User Name to "Freeloader" Ryan?
It suits! Lol
SAU is running a Texikhana on July 15th at Nirimba TAFE airfield. Keep your eye on SAU Events especially. There is a Macquarie Pass cruise June 17th I think; run as a non-official event.
Hi Ryan, its was me at the back of u and u were at the back of Terry N1 GTR and Pat was in the front. Than when I saw Terry and Pat booting it and u didn't. I couldn't control myself and I went pass u. Wasn't trying to race or anything but just had my car tuned 2 days before and this was the best streach of road to test it. Good to see u joining us. :cheers: Edited by rbscreamer
Wow sounds like the whole day was a whole lot of fun!...bit bummed that I wasn't able to join you guys. But it was good meeting Eddie,Braden and Pat during the jdmst meet and then meeting David, Nermina, Genelle, Matt and Terry at the initial meeting point. Hoping to catch up with those I haven't had the pleasure of speaking too/meeting yet during the next cruise and I will post some pics I took while we were at the carpark in Penrith a little later today. :)
Yeah haha don't worry I'll give u a run next time :)
yeah you were cool space pants but now C'mon...where the hell were your spacepants?!!
another pic,
i should be seeing some friend requests pretty soon on le stalkbook eh?
eh?
nah im not needy at all
:turned:
Stock boost from memory is 9psi.
Remove the restrictor, and goes to 14.
Again, this is from memory.
And i think the gauge isn't reading psi, its in another scale....
No problem Fernando, I'll try to swing pass your place one of these days to catch up. :thumbsup:
The skyline gauge is a measurement of millimeters of mecury as follows:
760mm HG (mecury) = 1 Bar = 14.6PSI
Sky(7) is the gauge in increments of 7 (i.e 0 to 7)
Sky(1) is the same gauge but in increments of a whole (i.e 0 to Full)
PSI -------- BAR ------ Sky(7) ---- Sky(1)
0.000 ----- 0.000 ----- 0.000 ----- 0.000
1.000 ----- 0.068 ----- 0.522 ----- 0.075
2.000 ----- 0.137 ----- 1.045 ----- 0.149
3.000 ----- 0.205 ----- 1.567 ----- 0.224
3.360 ----- 0.230 ----- 1.755 ----- 0.251
4.000 ----- 0.274 ----- 2.090 ----- 0.299
5.000 ----- 0.342 ----- 2.612 ----- 0.373
6.000 ----- 0.411 ----- 3.134 ----- 0.448
6.720 ----- 0.460 ----- 3.510 ----- 0.501
7.000 ----- 0.479 ----- 3.657 ----- 0.522
7.300 ----- 0.500 ----- 3.813 ----- 0.545
8.000 ----- 0.548 ----- 4.179 ----- 0.597
8.760 ----- 0.600 ----- 4.576 ----- 0.654
9.000 ----- 0.616 ----- 4.701 ----- 0.672
10.000 ---- 0.685 ----- 5.224 ----- 0.746
10.100 ---- 0.692 ----- 5.276 ----- 0.754
11.000 ---- 0.753 ----- 5.746 ----- 0.821
11.500 ---- 0.788 ----- 6.007 ----- 0.858
12.000 ---- 0.822 ----- 6.269 ----- 0.896
13.000 ---- 0.890 ----- 6.791 ----- 0.970
13.400 ---- 0.918 ----- 7.000 ----- 1.000
14.000 ---- 0.959 ----- 7.313 ----- 1.045
14.600 ---- 1.000 ----- 7.627 ----- 1.090
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
