Ok so this is it I've had a oil leak in my r32 gts4 since I've had it (4weeks) and I have had it with putting card borde and shit under my car :( I have located the leak coming from just under the the manifold at the rear of the motor I can see it dripping down under the manifold on it my external waste gate I got a mirror and I can see the oil forming on the bottom of the manifold bolts but can oil come from there and if not whats around that area that the oil
Could leak from?? HELP!!!
https://www.sau.com.au/forums/topic/398382-major-oil-leak-help/
Have a look above the manifold. It is extremely common for the rockers to leak.
^^^this is where it will be coming from, replace both rocker cover gaskets including the half moon seals and that will fix it
  • 2 months later...
I was going to sugest your oil drain line from your turbo.
Give it a good clean with degreaser and a high pressure hose, get it as clean as you can.
Then start having a look and see were it is coming from.
Could be the gasket has poped, or a bolt isn't tight enough and the prssure is casuing it to come out when the engine is running.
yeah thats what i first thought so i replaced the gasket, degreased the shit out of it and lay under the car with it running and i could see oil slowly bubbling out from one of the bolts that goes through the turbo core into the compressor housing. I couldnt get a socket or spanner up there to tighten the bastard up tho. Also seems to be leaking from above the manifold at the back some where. The joys of a 23yr old rb20det i guess
i got this problem also have you done a 100k service on the car yet, its a O ring seal that needs to be replaced which gets replaced when you do a 100k service, most ppl know the name of this seal but i forgot it hope some one can elaborate on that
yea thats it the cam and crank shaft seals should be replaced with that 200k service but its also called 100k , which water pump crank and cam pully and seals along with the belts should get changed on that service if it hasnt been done then take it back to ppl and say you didint do the right job and get them to do it,
other than that get a water pressure test to see if it is headgasket, i did on mien and was all good, and a cylinder compression test which i going to do that next
Edited by BRUNSKIGTST
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
