Heh, figured that would get your attention :)
Just for curiousity's sake mostly - I'd be interested in any info relating to serious n/a RB buildups, whether they be 11000rpm RB18DEs, RB36DE strokers, what have you - has anyone here built up a hardcore n/a RB engine, or know of websites, a friend's cousin's brother-in-law's dog's vet's car, whatever you know, post it up! (but especially interested in stroked "big-blocks")
Cheers
J
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/
Cheers
J
With the help of a lot of people, I went through the exercise a couple of years ago and found the result, totally untractable, as it wouldn't idle under 3000 revs.
Firstly, the RB30 has a non balance related HARMONICS problem at about 7500 and to go higher, which was necessary to attain the HP required, it is necessary to push through 7500 ASAP.
My goal was 300+ rwhp. And special things had to be done and cubic inches isn't the answer.
We had an RB30 block, bored 1mm o/size, RB26 crank and rods, for optimum rod ratio for high reving n/a engine, RB26 head and induction system, including 6 throttle bodies. Capacity 2760cc. 600cc injectors, Z32 AFM, Q45 throttle body, custom extractors, custom forged pistons 13.5:1, Inlet cam over 350 degrees, exhaust cam about 340 degrees and at 10700 rpm we had 342 Kw at the fly.
Our decision was to scrap the plan as it was impossible to drive this on the road and we went TURBO.
Cheers.
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-816448
RB26 rod: 120mm?
RB26 crank: 73.7mm
RB30 rod: 154mm
RB30 crank: 86mm
Add the fact the RB30 block is ~1 inch taller and by using RB26 rods + crank in an RB30 block you've got a piston sitting ~40mm down in the bore at t.d.c.
That's one massive piston you'd have to use...
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-816901
dont post bullshit titles :D.
Thought it should've been obvious :rofl:
id love to see a 300kw+ na RB tho.
-rb25
Same 'ere. So it sounds like big inches are not the solution - I guess one would have to start with an RB26 then. Wasn't there an RB26DE Nissan factory race engine a while back?
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-820832
Forced Induction does mean waiting for a turbo to spool... what about a super-charger?
instant power, but nothing up top.
hardly true about nothing up top.
Depends on blower matching more than anything else.
And the type too.
I'd be interested to see anyone even create an RB36 ROFL.
And how cant an RB30 rev out past 7500?
There are too many RB motors that i can think of that go past this without a drama.
Some twin cam (26head) some not (sohc)
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-821985
For non-forced induction.. you'd really have to an 8 to have any form of driveability.
i think the M3 does pushes the envelope for a 6cyl at pushing out 252kw.. Some of the best figures for a naturally aspirated 6cylinder I can think of. With some work probably 300kw. So just get an m3 engine and put them, i'm sure its an easy task :)
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-822131
don't get me wrong, a well tuned turbo car has plenty of response too... mine does :)
but the response of an NA car is relatively linear, even with systems like BMW's VANOS, Honda's VTEC, Toyota's VVTL-i, etc., and you can experience a different way of attacking corners. that's what I miss most about NA cars :rofl:
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-822513
i think it would b VERY hard to get the m3 to do any more than it does, as all its components are built for power, unless u added nos or forced induction, same goes for the s2000. as for the skyline, rb30 bottom end, gtr head, port, cams, exhuast, pod in box with CAI, comp, tune, would go along way
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-829075
if its still using basic valve timing its going to get to a point where you just can't get much further without killing the driveability at some point.
Don't know about the beamers, but bit of stuff I know can be done with the s2000 to give it more kick. Everything comes out of the factory for all conditions, all fuel quality, economy, etc.
https://www.sau.com.au/forums/topic/39873-300kw-rb36de/#findComment-829135
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
