Hi Everyone. :action-smiley-069:
Just wondering if their is any interest for Custom Aluminium rear diffusers for r34 GTRs.
I've gone through the whole process as im sure many of you have.
I have looked everywhere yahoo auction on SAU and can find any OEM rear Diffusers they're either to expensive 2k+ or they have been scooped up by a lucky member that was first in line.
So ive decided to make my own Rear diffuser out of aluminium. The Material thickness will be 2.5mm thick and the plastic fins will also re-made and replaced as alunium units.
The whole unit will be laser cut and hopefully be the same weight as the OEM one. Ive done away with the centre scoop as the wing provides enough down force and im hoping to achieve better air flow under the vehicle.
Ill be posting pics in a few days of the final Result :no:
Ross
https://www.sau.com.au/forums/topic/398748-gtr-34-rear-diffusers/
The first Concept one will obviously be alot more expensive because of the labour involved and all the CAD design but the Suppliers have Quoted around the $900.00 mark new including fins.Terry the Diffuser on my Gtr is cracked and that why i would like to get rid of it the plasic fins and Discolouring of the Carbon fibre Clear Coat isn't esthetically pleasing to me. Think brushed aluminium Would Suit!
Im keen to see your results for this. I created an autocad drawing a couple of months ago to do just this, after seeing what was done on the powertune GTRB28 car.
I took a little inspration from the ARC ones as well to make it a little more racey looking. Should be interesting to see what yours turns out like.
Sorry to hijack the thread....
I received my new diffuser on Friday - pics below, cost me in total $2,100.00. The item itself was $1,200.00 and customs crap / GST etc was $881.00!!! Took just over 6 weeks from order to pickup. Dealing with shipping companies was a major pain in the ass!
http://www.ioffer.co...board-202858506
Edited by 32godzilla
Anthony - fit was spot on, to the millimetre. I think it's a little thinner than the OEM one though, I'll check it against someone elses when we catch up next. But overall very happy.
Greatly appreciated mate.
Ps your car looks great, mnp is the color I wanted ha
Looks exactly the same as on my 1st R34 GTR
Yes the C/F is a fraction thinner - but not at all flimsy.
Peter of Bodyformaero had the diff bracket made up for me, because the kit didn't include that.
Making a front to back verson for gtt in carbon with quick release fasteners around parts that need serviced and jack points
and kevlar in strike points in front and rear so they wont crack , tested with ballpeen hammer not even a spiderweb on the clear
And of course vents for things that need it
and some other carbon kevlar goodness
Just saying
  • 1 month later...
Different subframe on the gtt, so they apparently don't fit straight up. I'm not sure what modifications would need to be done to fit.
Mine is currently off my car if you want to check
Edited by wedge_r34gtr
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
