Please find attached Autosport Time Attack Round 1 2012
Held under CAMS Club Permit No. TBA
Please send your 2012 Autosport Time Attack Round 1 Entry Form (with Payment) to:
Mitsubishi GSR/EVO Club
PO Box 10303
ADELAIDE SA 5000
Or
Fax 0882324446
Or
[email protected]
Direct Deposit Payment:
Mitsubishi GSR/EVO Club Inc
BSB: 085443
Acc#: 549085646 (NAB)
CASH PAYMENTS WILL NOT BE ACCEPTED
pdf-med.gifAutosport Time Attack Round 1 2012 ENTRY FORM
pdf-med.gifAutosport Time Attack Round 1 2012 SUPP REGS
Please note: Both Supp Regs and Entry Forms are in draft format and will be confirmed once we have notification from CAMS of the permit number. Please also be aware that there may be minor changes applied and to re-confirm your understanding of the Supp Regs prior to the day.
Edited by TPG
First off the rank for SA Motorsport Tyres entry in the Tuner Series 2012, Robert Catford makes a welcome comeback to club racing since his first time attack round appearance of 2011 in head turning fashion. Robbie successfully steered his 1988 Mitsubishi VR4 into the 1:20s in trying conditions, which many thought improbable for such a platform and in full club class specification. When this entry was filed for round 1 2012, we drew a closer interest and needed to find out more.
Fact is, this VR4 is not that highly modified under the hood as Robbie expanded; “Old men and old cars go hand in hand, and this is why the galant 4WD turbo appealed to me some 3 years ago when the opportunity rose to purchase from my nephew who had it stored away in a northern country barn caked in bull dust. Being imported from Japan in 2006, the VR4 was unmodified, unmolested, and had very limited kilometres. A blank canvas for a bit of fast fun and blood pumping adrenaline to scare some of the newest technologies. I must admit we are a bit off the pace when it comes to horsepower, but the true development has been focused on the driveline strength in anticipation for increased power once I get more seat time. I have worked closely with Mike Dale Automotive on this build who has dialled in a very driver rewarding differential set up, consisting of front and rear Kaaz LSDs and Evolution RS 4 bolt rear end. The driver feedback is absolutely sensational and brings back the enjoyment of application by driver – none of that AYC, ACD, ESC that those modern platforms possess. The trend doesn’t stop in the driveline; this VR4 boasts EVO 3 brakes, custom braided lines, project mu pads all round and an aftermarket coilover set up, so we can use every ounce of performance the original 2 litre 4G63 can pump out.”
“Mallala is a hard circuit for any club class car with the bare essentials for the discipline and certainly illuminates problem areas for any developing vehicle. We saw the demise of the gear set in our first outing and also noted slight radiator inefficiencies. Subsequently, VR4 had an extended omit from my 2011 club racing campaign, and in off season, mad scientist Mike Dale addressed the gear set with more desirable ratios and a thicker aftermarket EVO 3 radiator core. The gear set is pretty trick and complements the driveline allowing full use and abuse of the existing horsepower. I am very excited to be back into the time attack and hillclimb series with the amended inadequacies, and the new club class regulations play right into the direction of the build and driver deliverance. Last year’s shakedown was my first track day since 2007 and absolutely loved it. I know there is more in it, so we set out to dominate the class with a new set of Hankook Z221s from SA Motorsport Tyres, and driver aids such as harness set and Evo 9 Recaros, and if time permits a half cage to complete the package. This vehicle is still a roadie, and interior still remains to keep it compliant for the AWD Turbo Challenge series. The addition of the seats is sure keep me in one spot, those 1987 style galant seats and OEM seat belt are a little concerning – remember safety first!”
The Hankook competition tyre range has been very successful in time attack racing since they became very active in their marketing during 2010 and 2011 in Australia. Their Ventus-RS3 UTGQ 140 spec high performance street tyre and the Z221 semi-slick tyre have dominated respective classes in this discipline. Robbie takes full advantage of SA Motorsport Tyres on track support and advice when it comes to application and maintenance of race tyres for each event. “I was very impressed with the braking grip and stability of the Hankook Z221 215x45R17 semi-slicks we ran at this event last year, and will be my desired choice for the 2012 season. We are currently devising a plan for a wider tread package that should see us maximise grip and have superior heat management” Robbie suggested.
Driveline and tyre investment appear to be covered on this VR4, but more specifically, we need to know more about the horsepower these first generation DOHC 4G63’s can produce. Avoiding the confrontational questions thus far, Robbie finally divulged the details of the engine; “No secrets on the horsepower, a ‘limiting’ 206kw at the wheels. You see it is limited because of investment into other areas of the VR4’s development. Between Mike Dale Automotive and I, we are confident the ECMLink software and E85 custom tuning holds a sound performance and safety relationship to ensure engine reliability. However, in the case the inevitable foresees, I have been very proactive on saving empty beer cans for recycling, in the reality that the more you drink the more engine modifications your can afford! One day I will get the scary engine I deserve! For the interim, Mike Dale Automotive has produced a best result for the hardware I had available, and to be honest, it is a decent amount for the time being. Starting with the turbo an Evo 3 big 16G item with GTpumps high flow manifold, 910cc Siemens injectors, Kelford 264 intake, BC 272 exhaust cam shafts with resulting boost all controlled with a Greddy Profec B at 19psi gives this VR4 a nice starting plate for what is approximately a 1,450kg platform.”
With all things considered a decrease in Robbie’s personal best time will see him with a prime opportunity to contest the new club class for 2012, however realistic that other teams are more in tune with their track set-ups around the ratchet time of 1:15.00 for the class, but we all want to see this VR4 and Robbie keep them honest during the Tuner Series 2012.
Edited by TPG
Don't believe forum gossip,
Don't believe your best mate,
Don't believe your brothers, girlfriends, uncles, son who runs a Mitsubishi Eclipse with a MoTec System Exhaust......
This event IS going ahead!!
Get your entries in ASAP otherwise your Tuner House won't be in with a chance!
Edited by TPG
Correct, anyone can enter. It would be great to see some more gtr's/skylines at the event.
You will need a CAMS license though. If you look through the entry form there is different pricing structure, non-Mitsubishi GSR/Evo Club members also get complimentary 6 months membership to MGEC. This way you can join in on post-event de-briefs / banter for Round 2 / view pictures from the day.
Also if you don't have a CAMS license, there is an option to join MGEC/get Cams/Enter Rnd 1, it is the more expensive option as it involved membership fee's to CAMS etc. However we'll take care of everything.
As for lap times in Street Class - it seems each class is getting faster and faster each year, old benchmarks are nearly invalid. There has been a change in regulations for 2012 Autosport Time Attack. The entry level class (previously Club Class, now Street Class) must now run street tyres - akin to WTAC. Previous Club Class winners were around the 1:18:00 mark. So yes depending on what cars enter I expect the pointy end of Street Class to hover between 1:21:00 and 1:19:00. Have to see how fast people go on the day.
Also, with the lap times getting quicker all the time, proper safety gear is highly reccomended in all forms of motorsport. We're all happy to spend extra for better tyres or the best oils at a service, so please have the same mindset about safety gear. Time Attack Sponsor Autosport have put together this "Gear Guide" http://www.gsr-evo-club.net/viewtopic.php?f=130&t=14367 as a quick run down of the items you'll need.
And since I can't seem to edit my first post i'll put the event poster art here:
See you out there!!
Update for CAMS Permit:
Held under CAMS Club Permit No. 512/1106/01
Please note: Both Supp Regs and Entry Forms have now been approved by CAMS and the permit number is now attached. Please also be aware that there may be minor changes applied and to re-confirm your understanding of the Supp Regs prior to the day.
No you don't have to re-submit, the draft forms are still valid.
Some people wait till the approved documents are out, in case anything needs to be changed from CAMS point of view.
But everything was Approved by CAMS so we're good to go racing!
Edited by TPG
Long supporting privateer of Time Attack, Ryan Probert, reveals his strong intentions for the 2012 Tuner Series with the backing from Exhaust Technology. Ryan has dominated the RWD classes since his introduction in 2010 when his Nissan S14 had full street trim and standard turbo. Ryan suggests he is now hooked and has come a long way with vehicle development. Working hard during the offseason in order to charge the open class standings, Ryan has added polycarb side and rear windows, carbon/fibre glass boot, APR GTC-300 adjustable wing, new front custom splitter, and removal of the A/C.
Ryan has access to a wide range of aftermarket parts being the owner of ISC, a business that aim to bring in quality parts at an affordable price to the Japanese modified car market. “The S14 is basically a promotional car for our ISC parts, we have bolted everything onto the car from the ISC N1 coilovers, complete ISC suspension arms package up to the ISC adjustable cam gears, ISC 52mm alloy radiator and ISC front mount intercooler kit! The car is currently running a responsive 244rwkw with a disco potato (one step up from the standard turbo). The car definitely isn’t a power monster but the aim is to have to aero, brakes and handing 100% sorted before pumping anymore power through. The S14’s current Time Attack PB is a 1:17.69 around Mallala (Round 3 2011). Hopefully this year we can knock a second or two off that time!” he explained.
ISC are continually expanding each year releasing new and exciting products, and even support the local Time Attack and G1 Drift series. Ryan also has a thriving business association Exhaust Technology; “I have known Marky and Megan for quite some time now and have taken multiple cars there for exhaust and other custom fabrication work. I can definitely vouch for the high quality of workmanship that comes out of their shop. Exhaust Technology is also a re-seller for our ISC N1 coilovers along with our other ISC products. I look forward to giving Exhaust Technology some good exposure in 2012 and hopefully accumulating some championship points along the way.”
With the sexy new carbon additions and 18x9.5 Work Emotion 11R wheel package we can not wait to see this S14 in open class!
gt3?? mmmmmmmmmmmmm modified? fax somehow failed so scanning forms and emailing them now, cams liscence cam aswell. payment made last night.
thanks SO SO excited as this will be my first ever "competition event"
Nice work guys. Great to see a few more Nissans out there giving it a crack!
The two GT3's were only laying down high 1.18's on semi-slicks last year, so I wouldn't worry too much about them. ;)
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
