NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
shes gone forever!
i want her back now shes gone... but she will be replaced with mah new babeh soon which is even better than the last by far.
we found out something about the last owner of my the ceff beast and he was very happy when he found out that it was coming to melbourne because he was here about 2 months ago or so... as a driver IN THE DRIFT NATIONALS!! :):D:D
its his ex dorifto D1 car! ;)
https://www.sau.com.au/forums/topic/39894-my-baby-left-me-for-another-man/
um it wasn't in D1, but he is a D1 driver, and this was his sorta like non competition car... or so I was led to believe. But yeah he was very happy about it comin to melb as he plans to visit soon. He wasn't too happy bout the delays tho *coff* :)
yeah its got a few battle scars... one noticable un in the boot, but its purely cosmetic (no structural damage according to the mechanic) so narkeh's pretty confident he can fix it (him n his extended family being panelbeaters n all).
hahaha damn right its been thrashed and its gonna get thrashed when it gets here too! :):D
yeah it all looks pretty superficial from the report and from the pics... nothing a grinder, welder and a splash of fibreglass wont fix ;)
Confirmed: Car wasn't actually in the Drift comps, however we have VERY strong suspicions that it was his practice car when he was a budding drifter :( (can you tell?)
We're trying to organise for him to get a few shots with the car before it leaves Japan, and also when its down here he may come for a visit to see its new home.
the agent was a bit angry (trust me you don't wanna be on the fone to an angry jap dude) so I din wanna push the issue n ask what his name was lol. I'll ask him as soon as ni's money transfer clears (so he dun start yellin again).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
