its lowered alot yeah, what brand middle muffler, i dont wanna buy some crap muffler, alot of people have different idea of whats loud and whats not, but ive seen and heard alot of skylines around and they have some nice RB sound to them without being too bad, i could barely drive it to the exhaust shops, still got a headache
Might need to raise the car i think, discovered my dump is practically touching the underbody, :( another job..
So i got a rear muffler 3inch Xforce put on and its quite acceptable noise wise now :)
but the exhaust guy thinks theres a restrictor inside the hotdog resonator too, he showed me a resonator that he had and it was basically blocked on the inside with some insertion and spiraled wire around it,
he says this because he expected the car to sound alot more throaty, its suprisingly quiet,
so is this a common thing for hotdog resonators to have silencers in them on a Jap exhaust??????????
Edited by SliverS2
i would of never suspected this at all, looks like another thing to replace...
Does it matter what resonator you get or will a certain brand give it a better RB note?????
Looking at a MagnaFlow resonator from Rocket industries , $132 , the body is 6inch long and 6inch round, 3 1/2 inch
Would that be a good thing or not?
Edited by SliverS2
As long as it is 3.5inch through with no restriction it will be fine. The worst part about the restrictor in the resi its not something you can really check unless you chop it off and by that time you might aswell change it if you've chopped it off.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
