Hey everyone,
Have a heap of standard R32 GTR parts for sale...
Standard R32 Gtr turbos, both in great condition with no play, wheels in good condition only need a clean - $300
Standard turbo manifolds for rb26 - $100
Standard dumps rb26 - $50
Aircon setup for r32 gtr including compressor, radiator and hoses up to the firewall - $200
Standard Rb26 timing cover in blue - $50
standard R32 GTR camshafts with gears - $75
R32 GTR rear wing - $150
Standard RB26 intake manifold, no throttle bodies, does not leak and worked fine, just changed it for a plasmaman $100
Universal carbon wing at the moment the stands have spacers on each side to fit in the rear stock mount of the r32 gtr however front holes need to be drilled, had it on my r32 gtr before going a different direction is height adjustable i think 25cm and 40cm and is approx 155cm long, and about 26cm wide - $350 in great condition and has heavy duty feet for stands.
Standard r32 GTR brakes, front and rear, calipers are electric blue, rotors have a heap of meat left on them - $400
I can ship anything at the buyers expense, and open to offers on everything its all clogging up space and needs to go.
Contact me via PM or on 0434817247 and ill try to get back to you asap. All parts are located in Wollongong, about 1hr south of Sydney.
Na sorry mate, I'm not parting out the car, all these parts are lying around because the car has been modified somewhat significantly and they are all standard parts that I dont need...
Front Brakes sold!!!
Standard rear spoiler sold pending payment,
Bump on everything else make an offer!
Also have a full Hicas setup for r32 GTR including all lines that go to the front of the car $150
  • 3 weeks later...
Timing cover sold!
Long weekend bump!!!
Also have some 18x10 enzo D1R's in +18 offset, They have no rash or anything and are in excellent condition, wrapped in pirelli P Zero's front tyres are a bit worn on the inside rears are pretty much brand new, I think they have about 500kms on them. $1100 ono
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
