Carbon Ceramic Discs 380Mm Off F430
Don't ask why I have these, but up for sale are two 380mm x 36mm carbon ceramic discs off a ferrari f430.
The owner claimed 12,000 km's, which is sweet f all for carbon dics.
The have plenty of meat left and weigh next to nothing.
These do not include hats.
I understand that although these are awesome demand is low, so I'll put them up for
$300 for the pair
in syd
The discs are on the right below, do not include the calipers or rears
 Share
    • Hi mate, I have never had an issue with the odometer in mine (450,000+ klm now) and can't remember another post about it. Still, your description of the likely cause sounds spot on, so an electrics repair is probably the next stop.
    • Cheers. I more want it quieter with the varex open. I only have the varex closed when i start up and roll out the driveway to keep everyone happy on days i take the car to work at 5 AM or come home late. So just a mod muffler will do tge trick? Something like that would require a retune hey?
    • I was going to say generally speaking if it's like 80k+ miles since the valve cover has been replaced you don't even attempt to just replace the gasket. The valve cover itself will likely be warped and it will continue to leak after replacement, just not as severely. The valve cover PCV diaphragm can also tear and create a major vacuum leak. Welcome to BMW life. My friend's 2006 330i was t-boned and totaled out so he also just got a 335i so I can add to this thread now.
    • Hi all, For my '98 260rs... The odometer LCD occasionally turns blank or gives me only the bottom half or top half of the numbers. It's intermittent, which leaves me to believe it's a dead solder or loose wire somewhere. The odometer itself works. When the screen comes back, kms have been added to the trip and overall meters. A couple questions: Is this a known issue with the Stagea? I didn't see it pop up in my quick search, but that could be my searching skills. How accessible is the LCD screen in the cluster? I'm hoping it's a remove and replace type situation versus cracking open the whole housing. I'm hoping you all can narrow some of my initial troubleshooting. Any experience or opinions would be helpful.
    • Yeah. Seeing the finish line must be quite the motivation. Good on you for sticking with it. Understood about the model choice. Also, totally get the challenge with sourcing parts. Based on your handle, I'm just a few hours south of you. All the little things I've bought so far come with $30 shipping, even if it's just stickers for the boot!
