Originally posted by nissaner
saw that car at oran park last year's uas track day... it was also featured in zoom ???
yeah the driver was fat asssss, his stomach was touching the steeringwheel the whole time... maybe that explains his slow lap times??? :D
it was in Zoom with vic GTR plates
funny, i heard a rumour this car was seized by japanese authorities as the car had been stolen in japan and shipped here...rumour stated that the owner was given 1/2 its value by said authorities...
obviously something is amiss!
:bahaha:
https://www.sau.com.au/forums/topic/3994-whos-r34/#findComment-67262
yeah i heard something similar, a japanese insurance company tracked it down to aus (the zoom cover shot probly didnt help) and the "owner" was given the option of paying 50% of its value to keep it.. so if the rumour is true the guy either paid up and still has the car, or someone else in syd got a good deal :)
https://www.sau.com.au/forums/topic/3994-whos-r34/#findComment-67478
  • 3 weeks later...
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
