  • Replies 117
So I got a couple videos during the day in between my runs.
usual shit applies
reference SAU and myself if you want to use them elsewhere.
Contact me if you want to use them to in a commercial context.
high res MTS version:
http://sau.loudsx.com/deca%20may%2012/
low res MP4 version:
http://sau.loudsx.com/deca%20may%2012/lowres/
enjoy
usual shit applies
http://sau.loudsx.co...ay%2012/lowres/
enjoy
lol, "red r34 (3)" is exactly what we expect from Dave haha
"oops, tiny bit too much angle there, well, better go up a gear, hold it flat and dutchee this place up"
