Im currently parting out my R34 GTT with GTR runing gear. everything must go.
R34 GTR parts as follow
Gatrag 6 speed gearbox, perfect working order, good meat left on 4wd transfer case. comes with pull type AND push type fork and slave cylinder, 5month old nismo gearbox mount, and support brace, complete with GTR shift knob, AND front prop shaft: $4000
R34 GTR Year 2000 V-spec turbo, perfect with no shaft play $350/pair
STD GTR injectors $200/for 6
Pearl White GTR aluminium bonnet, minnor dent on the front area, fine as is or just a touch up: $500, bargin!
R34 GTR Tail shaft: $200
Light weight flywheel (7kg) and exedy heavy duty single plate clutch: use less than 9 month with light foot, never launch, just bed in. paid $1600, pull type $800
Vspec dash cluster, 25xxx or 26xxxkm on the clock (Rare very low K), no clouds, no marks. Perfect!. $200
Apexi boost controller. with leads. $50
front subframe, $150
Uprights: $150 ea side
Lower and uppper arm: $120 ea side
Steering Rack, 2.5 lock to lock : $150
Sway bar: $50
Front Shaft $120 ea
Or the whole front suspension setup $900
Std R34 gtr intank Fuel Pump. higher flow than pervious model, support up to 280kw awkw no worries, $120
V-spec very little k's travel. $650
V-spec hydroic pump assembly, wiring hardness been modified, suit spare $200
STD rb26 AFM $100
GTR twin turbo 60mm into 70mm front pipe. mines style, very good flow probably the best twin front pipe design. $250
34 gtr fujisubo Full exhaust. Jasma Approved. flows very well and very quite, 80mm main pipe, made over 300kw with this pipe before. $350
CATCO 3" High Flow cat, Brought for $200, selling $80
OEM R34 GTR sideskirt with front guard lower skirt, RHS minior twisted $250
GTR replica full carbon fiber rear wing with OEM height (custom requested for oem height) $350
R32/33 GTR parts:
R32/33 Apexi Power FC, complete with hand controller. a minor scrach on the hand controller but wont affect the readding at all $750
GTR BOV $120/ pair or $70 each.
R32 intercooler $70
Thick full alloy radiator 8 months old, suit R32 $80
Item located doncaster east Melbourne.
PM call or text 0433289998.
cheers
joe
Edited by godsmind
some pics on this thread
http://www.skylinesa...66#entry6333066
Boost controller is actually solenoid only. no actual control unit. sorry for the miss leading.
V-spec R34 diff very little k's travel. $600
Will upload as much pics as i could.
Edited by godsmind
Right hand Upright: $150
Right Lower and uppper arm: $120
Sway bar: $50
Right Front Shaft $120
V-spec Diff very little k's travel. $650
STD rb26 AFM $100
R32 intercooler $70
  • 1 month later...
  • 4 weeks later...
Sway bar: $50
STD rb26 AFM $100
R32 intercooler $70
hey man do u still have the lower controller arm?
