All parts are from a series 2 97 r33 gts manual. Had a impact in the front but fixable with a dressed front cut. It is fixable but I have decided to strip it. Just ask if you need something not listed. I will post most items. If its bigger I may get you to source your own courier. I can find at least one day a week I can meet a courier.
Also if you need something and the price is honestly a bit steep don't be afraid to have a chat to me about it. That doesn't mean I want to be low balled on everything but id like to think im fair and reasonable. If you disagree however please don't comment on that lol. If you would like pics please let me know. Il try and get pics tonight of the non standard gear.
Manual Conversion
Series 2 sunroof shell. Currently rolling with manual conversion installed. 3k Can be negotiated as to how much i remove or keep there. on repariable write off register
Full series 2 interior
Front seats
rear seats
COMPUTER $100
TAIL SHAFT $200
R200 WITH CRADLE DIFF IN VGC $250 ABS diff
Abs pump
DRIVESHAFTS $65 EACH
HICAS $80
POWER STEERING RACK $150
POWER STEERING BOTTLE $20
BRAKE MASTER CYLINDER $150
SWAY BARS $20 EACH
Horn $20
Front wiper motor - $50
Rear Wiper Motor - $50
STEERING COLUMN $50
(Body parts)
series 2 headligtht Passenger side 175
Passenger front guard $50 very slight mark
Drivers door 300
Pass door $300 includes glass window reg and everything
Boot very minor damage to rear drivers side lip. $60 no wing
Rear tail lights
(DASH PARTS)
turbo cluster with 167000km's $150
DASH NO CRACKS OR BUBLES OR HOLESLOOKS LIKE NEW with airbag $300
ALL VENTS $75
GLOVE BOX $30
CENTRE CONSOLE $150
CLIMATE CONTROL UNIT $75 BOTH BUTTONS WORK
HEATER CORE $70 A
IRCON CORE $70
HEATER FAN $20
(INTERIOR)
INDICATOR / WIPER SWICH Headlight, fog lights / ASSEMBLY $100
HANDBRAKE $30
REAR TRIMS $30 EACH
SEAT BELTS SET $150
INTERIOR LIGHT $15
PLUSH CARPET $70
PASSENGER DOOR TRIM $75
POWER WINDOW SWITCH PASS SIDE $25
BOOT TRIMS $70
POWER ANTENNA $50
PILLER TRIMS $20 EA
ROOF LINING $40
KICK PANELS $10 EACH
R33 GTST. Skuff plates, both sides $35
Rear Seats - $100
Door seals $25 each
Boot seal $25
Rear ¼ trims - $50 each
Rear1/4 window surrounds $50 each
A pillar Trims $20 each
B pillar trims
Door cards
Rear Vision Mirror $20
(ODDS AND ENDS)
FUEL TANK $30
FUEL PUMP $50
WASHER BOTTLE $20
RADIATOR OVERFLOW BOTTLE $20
WINDSCREEN $200
QUARTER GLASS $30
REAR WINDOW $200
BATTERY HOLDER $20
WIPERS $15
FUEL LINES $50
FUEL FLAP $10
FUEL CAP $10
Engine Mounts - $80
Radiator overflow bottle - $20
Stock BOV - $40
Sun visors $30
Handbrake assembly & cables - $160
Sing out if you need anything not listed. PM me or get me on 0424506009
  • Replies 41
Hey mate, If you cant sell the Shell whole, I may be interested in the sunroof glass part. Not the whole sunroof just the glass bit, but I might be prepared to buy the whole lot.
Let me know if your interested
I have alot of other parts not listed so dont be scared to ask. Also if prices are steep im happy to negotiate. Also do bulk prices on several items. Sent lots of stuff to wa and sa so far, will post most items.
Will sell sunroof roof lining, light / switch, right or left rear body cut. aps pump unit thing. na steering rack and lines, na cross member, rear bar, aftermarket catback exhaust, 17" 4 stud wheels, Right or left tail light. Airbox with k&n filter + snorkle, green lable afm, na intake pipe from airbox to tb. Series 2 airbag steering wheel or airbag from dash.
Will take 900 firm for manual conversion. Its in the way!
Edited by coaster
yep sure do mate. 0424506009. ur welcoem to ceh k out otehr bits as well.
I actually just bought a turbo wreck. yet to get it delivered though.
Hey,
Got these pipes/hoses?
Also the f###ing crows have been eating the rubber around the door/windscreen so do you have a gun? Whoa, a mean do you have the drivers side door rubber forsale?
Cheers
Simon
(Oh and ive just discovered the joys of image paint, hence the yellow lines!!!)
Edited by simdog
hey mate, good pics!makes it really easy to locate stuff.
I am fresh out of guns and dont have alot of the stock turbo pipes but il have a look. should have most or all of the rubbers you need. Let me know when u want to come check them out.
Oooh, keep me updated. I'm still chasing an RB25DET. I might also get around to grabbing that door card bracket too :P
Hey
Have you got any of those plastic clips that screw in? they are manly found in the boot area? i have not many and sub is currently holding the backing up. and also a lid for the windscreen wipers container? or complete unit would be fine.
thanx l8rs
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
