Hi, selling NISMO R-Tune Coilover Suspension for R34 GTT Skyline in Victoria.
Both Height and Shock adjustable by Knob at reachable level, even for the rear, unlike most other brands.
Condition: 85-90% new. Except for some road tar marks. No leaks of course, having been on car for only 3-4 months.
Reason of sale: baby along way, back to stock suspension for mother !
Price: due to as new condition, about $1900ono.
The NISMO R-Tune are designed by NISMO perfectly for the R34GTT. They are the top spec version for the R34, also about 25-30% more expensive than the HKS and TEIN equivalent - roughly $4000 for the set, brand new. Photos are of course, available, and Victorian buyers welcome to look at it in person WITHOUT obligation, hopefully all at about the same time though.
For Interstate buyers who pay $1900, I will subsidise the postage by charging Nothing..
https://www.sau.com.au/forums/topic/39993-r34-nismo-coilovers-r-tune-spec-gtt/
Thanks, replied and have sent pictures..
Here are the SPECS:
F9.0 (kgf/mm)
F8.0 (kgf/mm)
Just on borderline of Street vs Circuit spring rates.
Rear Shock Adjustment: 8 turns on knob with numbering
Front Shock Adjustment : 4 turns on knob with numbering
Lowers Front -35mm
Lowers rear - 20mm
The G-Attack S-Tune, in comparison, is 6.4K front and 4.6K rear, similar to say TEIN Type Flex, which is usually said to be too soft for even street use by many users.
Thanks, please PM me or call me on 0400167761 to take a look, no obligations!
Hi guys, thanks for replying.
Pics have been sent to Amadeo, if Adzmax could leave his email addy too, I'll send them to you asap later tonight thanks!
Regarding the spring rates - I am not sure how familiar you guys are with suspensions or track work, but if these were to go on the track they're probably JUST slightly too soft. To me I think they were just right for the R34 GTT even on the street, and also since the sound insulation is good on the R34's it doesn't seem to have too much of an NVH issue either, unlike on other cars such as the S15s.
This coming from NISMO, I reckon you can believe in their choice - but whether it is too hard for you it is too hard to quantify ^_^
Hi Muz,
Ok just to let you know, the other person has given me $500 to take away a bit of the suspension already :) and then will come back and take the rest of it... when he has enough money next week! :D
So sorry that we couldn't deal this time!
With the Hiper Max II you're getting from this other person, they're normally worth about 20% less than the NISMO from Japan - so I think $2000 if they're use might be a little bit expensive ? Perhaps try to talk down the price a bit..
I normally import brand new coilovers as well, although these few weeks I am not doing them anymore as I might have to head overseas for work suddenly!
Anyway, all the best with getting your coilovers..
Warmest regards
Kelvin
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
