G'Day All,
Recently purchased a R34 GTR, did all the usual checks.. workshop check and pits inspection all passed fine.
However, my mate mentioned tonight when I take corners from time to time he sees sparks coming from under my tyres..
We looked further and noticed crazy excessive wear on the inner of both front tyres:
The previous owner had Tein Superstreet Coilovers fitted to this car so I'm thinking he either had a very stupid camber set..
Previously I thought he moved the rear tyres to the front.. but on second thoughts I'm doubting you could get wear like that happening on the rear..
It's safe to say I'm now ordering 2 brand new 275/45/19 tyres as I've got that profile on all 4 tyres, all around.
Any thoughts on what caused this fellas?
https://www.sau.com.au/forums/topic/399987-excessive-tyre-wear-r34-gtr/
there is no way those tyres passed inspection by a competant workshop.
most likely they were on the rear, because lowering makes a bigger difference to camber in the rear.
you should get a wheel alignment, and make sure they tell you the "after" settings. If you have too much camber you need to raise the car, add adjustable bushes, or worst case, add adjustable arms
+1, get a wheel alignment and see whats going on, when i first brought my 32 it chewed out a pair of tyres in 2500kms, got a wheel alignment and the front had 6.5mm of toe each side so it drove straight but was very twitchy when turning and made the tyres look like yours
Agree with Duncan. Inspections would have picked that up. RWC would not have happened with that tread.
How long was it between your purchase and noticing this?
Weeks or days?
Unless you've been doing burnouts or hard driving, it would have been very low to begin with.
G'Day Fellas,
The inspections here in WA arn't as strict and due to them being quite lazy they probably only checked the middle and outer tyre wear and ticked it off.
A RWC is not required here in WA for the car to be registered, a re-inspection is.
I just noticed it now and haven't been doing any burnouts or hard driving.
The front tyres have always looked a little worn so I'm assuming it's been like that for a while!
Just had a further look.. I'm running 3 different types of tyres.
Front Tyres:
Bridgestone Potenza RE-01R
275/30 R19 (92W)
Rear Left:
Continential SportContact2
275/30 ZR19 (96Y)
Rear Right:
Pirelli PZero Rosso
275/30 ZR19 (96Y)
I'm not really sure on the difference between 96Y/96W and 92W, etc.. Something to do with weight and speed rating?
I definately need 2x front new tyres. The profile is 275/30 19 inch.
Should I just get 2x new 275/30/19 96Y's of any brand?
Opinions would be great!
Geez. Where did you buy this.
Good thing the fronts are the same. So someone was cluey.
Weird rules.
Get a wheel alignment at the very least after new tyres and keep an eye on it.
Hard to say if there is quick wear if you haven't had it for very long.
Is the car lowered?
This car is ex-TPG34R and I purchased it off the previous owner (not Ben).
Ben has been helpful and the previous owner was not unfortunately.
The previous owner was instructed by Ben to change the front 2 tyres (The Bridgestones) as they already had bad wear due to the camber setup on the front (which is set to -2) which I believe is the cause of the excessive wear.
The car is sitting on King Springs at the moment with custom Racepace front adjustable control arms.
The ride height isnt that low, I'm content with the way it looks for now.. However, it is definately comfortable to drive!
Very reluctant going Coilovers as it's very bouncy on the straights and quite uncomfortable (so I've been told)
Hi mate,
To be frank, those tyres, and a mix of tyres is downright dangerous. Whoever sold you the car sold you a car that is not roadworthy. There is no way even an incompetant inspection would have missed that.
You have bought one of the best performance cars ever made, and the 4 bits holding it on the ground are mismatched rubbish. So.....go and buy 4 new tyres. Look at brands like Federal or Falken or Kumho, you should be able to get a set for $1000-$1500.
If buying 275/19s is a problem price wise, sell the wheels and go back to 18x8 or 18x9, the tyres will be 30-50% cheaper. A better quality, smaller tyre will always grip better than a huge, cheap one.
Get the alignment done, and check the after settings. 2o is not a lot of camber and is not the cause of that wear, so maybe the toe is wrong.
While you are at it....if the tyres are that bad, the fluids probably have never been changed either. I'd change all the fluids (diff, gearbox, xfer case, attessa) to give your car the best chance to run reliably for years.
Any of you had experience with the following brands:
Dunlop SP Sport Maxx TT
or
Nitto Invo
I hear the Nitto Invo are the next best thing to come out and apparently #1 in America?
I also hear the Dunlop SP Sport Maxx TT are quite good but loud tyres?
Any feedback fellas?
you should be able to pick up a set of Bridgestone re01's (or re02's) at that price.
Walk into tyre shop and ask or even ring. You will always get a better deal then looking online.
Also check out the traders section here. Always tyres for sale.
Edited by wedge_r34gtr
Great tyre, they have converted me back to Dunlop. Last well, not noisy, and they grip right down to being worn out. I have had plenty of other tyres that got 5000 or 10000km into them, hardened up and was like driving on ice in the rain. The TT's stay grippy for much longer. Recommended.
I just replaced the rears after 25,000km, the fronts still have heaps of meat left on them. Can't work out why :whistling: I expect if I was able to rotate tyres (running different sizes F-R) I would get 35-40k out of a full set. More if my right foot didn't weigh more than my left one :banana:
Geoff
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
