Need abit of help choosing the right gear for my motor!
Its a RB30e r31 motor with roughly 140,000 kms on the clock
im after a turbo that would be appropriate for drifting , not after a lag monster, but nothing to small? possibly only want to run 14psi max im guessing for a standard motor with a new headgasket?
Also would i get away with drifting using a rb30 gearbox? or should i try and chase up a rb25 box or VL turbo box?
And would it be worth throwing a cam in it?
Sorry in advance if this isn't the correct forum for my questions, and thanks to anyone who has help on this topic!
cheers,
https://www.sau.com.au/forums/topic/400051-rb30et/
I have a 25 neodet motor coming my way next week >.> it only comes with a engine loom and computer, if i wire up a push button start system, with battery and indevidual fuel pump switch, should i be able to start the motor with just the wiring that goes with the engine??
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6356309
Yes, but you will have some fault codes. TCS/ABS at the very least. If you do not have the (ECU, not dash) boost sensor plugged into the engine loom, then a code for that too.
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6356912
No. Not that simple. Boost sensor is easy. TCS system is a whole 'nother story. The TCS system has its own computer that reads the wheel speed sensors and actuates the TCS throttle butterfly (upstream of the engine's normal throttle). The TCS butterfly has a position sensor on it.
When you start the R34 engine up, the engine ECU looks to see if the TCS system drives the TCS butterfly closed then open (start up self check). If it does not see that, it raises a code. Also, if the TCS computer is not present, then the ECU will raise a fault code because of the comms failure. You can only have it all work if you have a functioning TCS computer, which will probably raise fault codes of it's own if you don't have all the wheel speed sensors etc.
You can use a Nistuned ECU with a Stagea image in it (no TCS in Stageas) but my recent experience with doing so is that the automatic transmission Stagea images that are available cause driveability problems with manual Neo cars.
https://www.sau.com.au/forums/topic/400051-rb30et/#findComment-6358692
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
