Yeh I paid. I don't think I had any choice. What I think happened and what I can prove happened are two very different things. I wouldn't have had a foot to stand on if I refused to pay.
Yeh, they kinda had you up against a wall. I feel for you man, you have had such bad luck with your car.
  • Replies 104
man that casting is rough on that manifold... but never the less some heavy handed spanner work obviously caused it.
i find it strange that its fine when warm but once hot it reads 0 psi compression... usually takes a hole or a valve stuck open to actually get NO compression.
That's exactly what my tuner thinks is happening... That the valve is sticking open. But why would it be temperature related? Surely there's either fragments in there or there isn't?
The work and the tune where done at 2 different workshops werent they?
How did they stop the leak then? Metal putty?
I did the original work of installing the plenum, fuel rail, injectors, etc. after doing the injectors I obviously wasn't able to start the car, so I towed it to the workshop a bit over a month ago expecting that all it would need was a tune. Then the problems developed and the workshop did all work from there until I picked it up today.
They pulled the whole manifold off and replaced it.
my original theory when i heard about this is that a valve is burnt and still seats ok in its place.
dont forget that while the motor is running the valves can rotate, just like the rings can.
so my theory goes; the valve seats OK in one spot, but rotates a little and jams open. could definitely be related to a LITTLE bit of debris being ingested AND revving to redline the moment its started would quite easily do some damage.
Possible. But if that were the case, why would it only come good after the motor has been switched off and allowed to cool down?
It could be something totally different. I have found when listening to someones diagnosis alot of time can be spent chasing what they think is the issue.
I think it would be good to try and get the issue to happen on the road ( if it happens) and then check urself if it is a compression issue or a simple ignition issue etc
I do agree, and I would actually really like to see for myself what is going on. Except I can't, because he hasn't tuned the thing above 5000rpm. He set a 5000rpm limiter, which I could remove if I wanted to, but with no tune in the thing I really don't want to be smashing around under full load trying to get it to drop a cylinder.
How can he not have tuned it above 5000? So the issue is happening during low load steady state tuning?
If he has tuned up to 5000 then the rest will be there.
No, the issue is happening under full load. He didn't manage to do the full load tune because of the issue, so he has tuned it where it is ok and set the rev limiter to where he has tuned to. If that makes sense?
I cant see how they justify the cost when the full tune really hasnt been done.
Do they expect you to come back to complere the task?
Or are they saying once the 'leak' has been fixed its ready to drive?
I don't know. The majority of the cost was for "diagnosing running problems and replacing intake manifold". There was a fair bit of GST as well. There is no leak anymore, it's driving fine. The issue now is that it loses compression on one cylinder under load. It won't be ready to drive once I've fixed that, because it isn't tuned under full load.
Did you drill the lower manifold for the studs to push through origionally? Or did you somehow manage to screw the studs through both manifolds with an air gap between the 2?
Didn't drill them. Screwed them in from the top, then put the plenum on and threaded them back up. There was definitely no gap, I did the other studs first.
If I was to do it again, I would drill out the holes.
Well there's your air leak. Tightening the the nuts with the stud threaded into both sides would not of clamped the manifolds together.
I uh... I think you should read the last couple of pages of the thread :mellow:
TL:DR strikes again
Martin, when you tightened the bolts on the plenum how did you do it.
Did you start in the middle and work your way around tightening them like you would headbolts.
Or did you just tighten one end right up tight then do the other end.
This could of quite easily slightly twisted the manifold to some extent, then starting it up and applying some heat and vibration has cracked it pretty much instantly.. I would say the shop has just taken it off to see if it is leaking and thats when they spotted it..
I did them up as you said, starting from the middle and going around. Didn't tighten them up straight away either, I would wind each stud in a few threads, then do the next one and so on until I had them all done up. Took me a good hour to hour and a half to do.
did you use a torque wrench of sorts when you did up the bolts?
Im thinking if the sealant used was uneven it could of created pressure on that part.
if there was more sealant near cylinder 2,3,4 then that would create a lump or see-saw that cylinder 1 bolt (the flange part that broke) had more pressure on it.
could of been like bolting it up to a warped flange.
I dont think its clear who or what has broken that part.
Still damn annoying that they charged for the tune considering it couldnt be complete, I guess its still time spent working on it though.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
