  • Replies 160
Demon Hunter, level 18 at the moment, a bit slower than you guys,but I am investigating every bit of the map as i go through it. Just starting scene 2 after killing the *spoiler alert*........................................ butcher.
So question for you.
With your money, do you save for better items, OR do you train your smith to make better items?
finished the first run thru today. Diablo is a sweet fight! if a little frustrating
Yeah i finished first pass couple of days ago as well, but found the Diablo Battle was way to easy passed it first go no hesitations, the Butcher on the other hand i died heaps of times. Still happy with the overall game but :yes:
im playing normal mode, act 3 and Ive had enough money just collecting blues and yellows and selling approx 70%, salvaging 30% (salvage the low value blues the blues all give the same ingredients and quantities). Only sold 1 thing on the auction house a unique? (Dark gold/brown named item) witch doctor mask i got 10k for. But i always explore areas fully and loot everything. Selling magic items isnt that lucrative where I'm at, better off with gold drops. Both jeweller and blacksmith trained up to the point where i need the pages found in nightmare mode to go further.
Edited by gregor
I'm working on training up the gem crafter as well as the blacksmith guy. I never buy/ craft any armour or weapons because the drops are always better at this stage. Gem crafter on the other hand has been very useful.
Yeah up to the level with the jeweler where i need 10 tomes to go any further. Would love to be able to buy chipped gems etc, maybe you can later but i can at the moment, i just get them in the occasional drops. Really want a gem to make my attack % speed increase, i think that makes the biggest difference.
Blacksmith though seems to be ok.
Blacksmith is willing to make a rare belt for me but its a level 26 minimum and currently on 24.
Not getting any really good or rare items in my drops better than what i have right now. Most of my magic items sell for about 150, nothing over 200 gold coins yet.
Still on Act 2, so no doubt as things progress they will get better.
Any of you guys getting this continual patch update loop?
I am on the Asia server, basically i selected ok to do the patch, exits the game, downloads a 1gb patch, says its installed, goes to play the game then says you need to install the patch then kicks you off, then repeats like this.
So cannot play the game.
Unbeleivable. nearly finished act 2 as well onto the final boss, but has now been about 3 days i have lost connection.
Have tried changing the server to us which it lets me play, but all the way back to the begining with a new character F&*k that!
this has got to be the worst launch of a game i have ever seen.
My wizard sucks at the moment.
Haven't been able to find any good gear. So am going through the auction house, but im close to level 60 (58).
Friends told me to wait a little, the drops in Inferno are quite good.
Yea act 2 on hell lvl 55 wizard. Those special mobs are a pain. Worst combos - mortar, teleport, arcane or mortar, fire chains & waller. Sometimes you come across mobs that have invulnerable shields on and you gotta kill the main one first...Good challenge though!
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
