So i have taken to putting in an aftermarket temp sensor and TEFBA inline filter into my cooling system. Naturally these both need to go into the top hose (outlet) which is sadly a very short and mildly convaluted.
I have modified the hose path to be able to get in the sensor uit and tefba filter with a set of hoses as shown.
I was just wondering from the people in the know (people just throwing out ideas and opinions try to hold back) if this is going to be ok and the cooling system is going to still work fine based on the hose path.
2 points worth noting.
-the hoses i have utilised are all sitting as per their original design. that is; there is no angles being forced on the hoses, nor any pulling or twisting going on that will cause the hose to crimp under heat/pressure.
-the hose is still always in an ascending gradient. it doesnt go up n down along its path from engine outlet to radiator inlet (see pics). it is still a steady upward gradient as per original design which im sure is necessary in coolant hoses.
This going to be fine or any reasons why not?
Obviously my main thought of issue is the 100 degree bend now utlised between the sensor and filter, which was not in the original RB25 design. However some cars do use such extreme bends in their radiator hosing so i can imagine why it would create and issue here...
cheers
Justin
https://www.sau.com.au/forums/topic/400375-radiator-top-hose-modifications/
Should be fine, but can I ask what purpose the filter serves? Naturally I can hazard a guess at what it does, but having seen a multitude of high performance engines and never coming across a filter in the cooling system before, I can't see why it would be necessary?
+1 for the inline filter.
If the cooling system is filled with the correct coolant, and replaced regularly; there is no need to filter anything.
Every joint you put in these hoses is just another potential point of failure.
Filter is good, Ive got one, when I had my engine rebuilt they installed one, it caught a heap of silicon and other shit from the rebuild, even though the motor was chemicaly cleaned it still got little bits of shit, mine is a RB25/30 so the block well over 20 yrs old, over that time no matter how good you maintain it the metals will breakdown, where does these little bits of rust and gunk go, through your water pump and/or blocking the cores of your radiator, unless you have a filter.
If they were not any use they wouldnt put them on new trucks and heavy plant, all our new trucks and heavy plant have colling system filters.
But if you happy to damage water pumps or have blockages in your radiator dont use one.
Engine rebuild 2 yrs ago (ish), coolant changed every oil change which is after every track day or on average 1000klm.
Track day tomorrow, this thread reminded me to check filter and clean.
Here is what it stops going through the system;
The proof is in the pudding.
couldnt agree more on the benefits of an in line radiator filter, the TEFBA filter has stainless mesh and is a quality item. . . im sure everyone knows here to use quality coolant and soft water but as just about all cars on this forum are secondhand who knows what the previous owner(s) have used in thier cooling systems?
why use one?!
this and this.
N iv had several skylines now n been through the joys of 2 clogging radiators. We have near on 20yr old cars now that are notorious for doing it...
Also im now running some higher power through it and i live in perth with out lovely 46 degree days in summer. Want that thing running properly...
why use one?!
this and this.
fark yeah, for the cost of a radiator cleanout and the possibility of a cooked engine its good insurance to have a filter
cheers
Justin
it should be fine if its still below the air bleeder on your cooling system
yep. below the bleeder and even radiator cap.
CLeaned it out for the first time last night n the mesh was clear but the magnet had lost of rusty flake residue...
Glad this thing is there if it is removing this kind of gunk...
Will update this with comments as in the next few weeks im going to run a flush through the system so ill tell you what gets caught when i do that.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
