hi selling a whole lot of stuff ive had sitting around
also have a complete r33 minus engine and box
so if you need anything off a 33 let me know what your after
cheers
blitz power meter id -$200
gizzmo electronic boost controller -$200
autometer 2 inch silver faced air fuel ratio gauge -$80
autometer 2 5/8 black faced boost gauge with mounting cup -$100
75x300x600 front mount intercooler -$100
r33 gtr intercooler -$200
r33 gtr front reo -$200
gtr injectors -$200
adjustable fuel reg (might be malpassi) -$60
FET tb202 turbo timer good working condition -$50
BOSCH 746 fuel pump (used for about 2 months before engine was removed) -$150
TURBOSMART type2 v port bov almost new -$120
MONZA dual trumpet bov brand new in packet -$100
GREDDY bov(bolts to stock rb cross over pipe) -$100
S13/r32 tanabe rear coilovers no knocks -$200
s14 cusco front strut brace -$150
R33 front strut brace -$100
R33 NISMO front strut brace with brake stopper -$180
R33 rear strut brace -$100
GC8 WRX/FORESTER front and rear strut braces -$100each
CA STUFF
ca18 stainless low mount tune length manifold brand new -$150
ca18 manual tail shaft -$100
ca18 manual pedal setup -$150
ca18 stock manual radiator -$80
ca18 engine loom -$100
ca18 afm -$50
ca18 cas -$50
ca18 alternator/pwr steering pump/starter motor -$50 each
ca18 flywheel and almost new excedy clutch -$150
ca front seats -$100 pair
car rear seats -$80 set
SR STUFF
s14 t28 with snout with lines -$400
stainless split dump with stainless 3inch front pipe -$200
RB STUFF
Rb25det series 2 head complete head including inlet plenum (no coilpacks or injectors) -$300 has a bent valve
Rb25 top feed billet fuel rail hks copy brand new -$100
remote oil cooler with remote oil filter (just uses rubber hoses) -$200
RB25det series 2 air flow meter -$150
RB20det stock injectors -$100
RB25det stock injectors in stock rail -$100
RB20det 5 speed ecu -$100
rb25det 5 speed ecu -$100
R32 cross member -$100
RB20/25 series 1 stock coilpacks -$100
Rb25 series 2 coil packs -$200
rb25 lightened flywheel -$100
rb20/25 flywheel and used excedy clutch bit of meat left -$150
R32 STUFF
4 door front seats -$100 pair
gtst bonnet couple little dimples -$100
front gaurds have been rolled not the best -$60 the pair
rear tanabe coilovers no knocks -$200
4 door boot -$50
7 point bolt in roll cage complete with bolts and base plates -$700
R33 STUFF
R33 brake set up consists of
front and rear hubs,front and rear drilled rotors,front and rear calipers,hand brake setup -$800
R33 boot -$100
R33 bonnet -$200
R33 front guards -$100each
R33 head lights -$300 pair no broken mounts
R33 tail lights -$50 each
R33 rear bar -$80
R33 lower control arms -$150 pair
R33 front reo -$100
R33 rear reo -$100
R33 coupe m spec side skirts (1 crack on the side of each(bit that hooks around) -$100
R33 coupe m spec rear pods -$60
R33 front seats -$150 pair no rips
R33 rear seats -$80
most 33 interior up for grabs aswell hit me up if after something
RANDOM BODY PARTS
R32 gtst bonnet couple very small like dimples -$100
silvia boot -$100
silvia rear tail lights -$50 each
silvia stock rear bar great condition not cracked -$100
silvia rear reo -$100
can get any pics if needed just hit me up
located near byron bay in northern nsw bout 30 mins past tweed heads
Edited by team carefactor
  • Replies 60
also have some R34 parts
stock turbo front bar -$200
stock front gaurds -$100 each
nismo 300km dash cluster -$250 (one small crack in outer plastic)
Nismo strut brace sold pending payment.
No stock steering wheel sorry well not in very good nick ;)
Pm me about the reo if you want
Body parts are series 1
Thanks
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
