Brought the car last week and changed the oil today, was reading about 2.5kg/cm2 on the aftermarket greedy gauge and pretty much the same on the stock gauge
After changing the oil and overfilling a litre to accommodate for the remote filter kit and oil cooler the oil pressure is now reading 5kg/cm2 at 1500 rpm when at operating temperature 80 degrees, anyone knows what's up or is it nothing much to worry about? Has a tomei pump
https://www.sau.com.au/forums/topic/400559-rb26-high-oil-pressure/
5kg/cm2 is too high for operating temperature in my opinion unless that's how the pump was configured and something the previous owner did to mask the high oil pressure to make it read 2.5kg/cm2 (running low on oil, oil heavily dilated by fuel etc).
How much came out and how much exactly did you put in?
What oil and weight did the previous owner use, and what oil did you use (maybe too thick)?
What was the old filter, and what is the new filter (might be blocked/faulty)?
Was a bit low when I dumped it rough guess about 3 litres came out
I put the same oil back in
Running 5-60w penrite
Cars idling at 1500rpm that's why I said its 5kg at 1500 rpm
Tryed a couple of things to bring the idle back down today but also no luck, could it just be tuned to idle at 1500? It's running a motec m800 computer and has a single throttle body instead of the 6 individuals
I see 2 problems. 3l might explain why the gauge read 2.5kg/cm2. The other is the oil choice w60 (hot rating) is way too thick for a RB26, w40 is the perfect one (only reason to run a 60 weighted oil in an RB is if the engine tolerances were built for it, or it has massive blowby problems, or perhaps a track-only car)
Ahhk
Well it has a built motor and just seen everyone was running 10-60w so thought it was ok
It's done 5000k's on this oil
It has 272 degree cams and a t51r turbo so its gunna be revving pretty high
If you still reckon 40w is the go I'll go get some next week and dump what's in it and see how it goes
Awk thanks man
I'll ring the guy who built the car and try get ahold of the engine builder
But running 5 bar at 1500 will it do any damage?
I think I remember seeing it only raising to 8 bar at 9000rpm
Only drivin it once only 500 Metres down the road
Was no metal in the oil I dumped or in the filter but I didn't cut it fully apart
Cheers everyone for the ideas
Problem found
Jiffo inboxed me and guessed what it was straight away
The last oil filter didn't have a anti drain valve in it and the new one does
The inlet and outlet hoses on the remote filter are back to front
Actually not sure
It only dropped one bar on cold start and didn't seem to want to run so I switched it back just incase
Was doing the same thing after I switched it till I gave it a lil rev when I was starting up
After checking a hosing diagram on the net it seems to be done right, could the tomei pump just be adjusted that high as they have a external regulator on them dont they?
Edited by I_heart_rb26:)
The anti-drain back valve is just a rubber flap that keeps the oil inside the filter on shutdown so there is oil in the filter on startup. I asked which filter came off as you could have the wrong filter (filter relocation kits sometimes need a different filter) or a faulty filter.
2kg/cm2 would be perfectly normal for a unopened RB26 (with factory oil pump) at idle at operating temperature, because the engine is built and has a higher flowing pump (different oil restrictors too etc), it's hard to say what is safe or not.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
