Hi all selling my car as i don't ever drive it anymore just sits there would rather it go to a good home.
1989 z20 soarer 152000 ish km can’t remember off top of my head, pearl white over silver,
Originally 7mgte auto
Now 1jzgte r154manual was done 20,000km, engine package has 112000 ish km on it can’t remember off top of my head. Its all legally complied with 1jz,all that’s delectable is height and steering wheel
Jza70 brakes
New tie rod ends
Power steering rack bushes
Hks pod
Hks hard intake
Front mount intercooler with custom piping
New ngk plugs when conversion was done
New gates timing belt when conversion was done
New 2jz water pump and housing when conversion was done
Starter motor rebuilt when conversion was done
New battery when conversion was done
Battery moved to boot
Fuse boxes that were in engine bay have been custom mounted in inner gaurds
New thermo fan when conversion was done
New condenser fan when conversion was done
Aircon serviced when conversion was done
Brake fluid, gearbox oil, engine oil, coolant changed on 15-5-2012
Engine oil changed every 5000km
Weds 18inch mags,
3inch cat back exhaust
Lowered
Nardi steering wheel
Kenwood cd player,jaycar front 6inch split,rear 6x9s,amp to run 6x9s,12inch jaycar sub,amp for sub
Rego until 15-8-2012
Total detailed 15-5-2012
Probly forgot other things
The bad, power steering rack is weeping, dash cracked but have good condition spare of both just haven’t fitted them.
Comes with factory kit, fog light front bar, side skirts
Good condition dash
Radiator,Condensor, Power steering rack, Standard suspension, Standard rims.
Heaps of other spares.
Located Strathalbyn South Australia, $10,500 FIRM,NO SWAPS unless you have a madza 3
r154 manual
https://www.sau.com.au/forums/topic/400714-z20-soarer-1jz-manualvery-clean-sa/
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
