Pulled a few parts out of my S2 R33 & replaced for aftermarket stuff.
A-LSD Vspec Diff comes with reservoir and pump - $300
Factory turbo setup on stock manifold with dump pipe (turbo in shmick condition, minimal shaft play and no oil blow through)- $400
Stock Radiator - $50
Monza Intercooler (few bent fins but no leaks) - $50 may even have a complete piping set as well for an extra cost.
Factory Inlet Manifold - $150
Factory Injectors - $150
This stuff would be great for someone looking to turbo a GTS or something.
Call me on 0407101066
Im in Kogarah NSW.
At the moment the diff centre is out of the housing, So I will let it go for $150.
Since posting the S2 diff up a few things have changed and it is actually now a S1 diff.
I bought a Kaaz 2 way second hand and it came in a S1 housing, I thought it would fit straight up, but in fact they dont.
The series 2's have an ABS sensor on the front of them which lengthens the diff by about 50mm or so.
What I did was pull the Kaaz out of the S1 housing and put it in my S2 housing, so what I have got now is a S1 housing and a shimmed centre.
All you have got to do is drop the centre in, put the cover on and throw it in the car.
When I shimmed it I packed it until it couldnt take anymore, i took out one of the factory shims and put in two i think 1.49 shims.
Did it properly and did both sides.
At first it was sick and was pretty much a complete locker, but eventually it started to loosen up a bit. Still locks up dualies with a clutch dump from a standing start, but when drifting, sometimes it single spins for a litttle bit before kicking out. Whoever buys it can have the stock shim that I took out, and while the centre is out they should put that back in as well and then it will be nice and tight again.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
