Real interested to know if the original tune was by the same tuner ? If the before tune was by the same guy then that removes a variable of it being overly conservative
i assume so if they have the old data on hand, anthony does all the tuning down at Jaustech. from the owner:
"Before I put the tomei poncams an tomei gears in I was already running a z32, Walbro 500hp intank, gtr injectors, nistune, hypergear atr43ss1, blitz highflowed 3inch turbo back zorst, fmic. That's almost everything I can think of atm.
Results really depend on how big the cams are, these drop in and are built to respond in the mid range more than bigger cams. Big cams will be sluggish but have lots of topend so not real good for a streeter. These would be as big as I'd go, you want response for a quick car and this is a good example! Just went through adleaide hills last night, very quick!"
it doesn't tell you much, but that was in response to me asking if anything else had been done between dyno's.
i'm thinking the same, i have them sitting there, and although i've had a few bites i think i'd rather just chuck them in for now and see what they do, worst comes to worse i can rip them out later.
although at the same time tempted to just sit back and watch you put them in first haha
hey guys, just to confirm, this is the one i'm after yeh?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-TD06SL2-20G-w-T3-8cm-V-Band-Hsg-No-Anti-Surge-Inlet-/290709333589?pt=AU_Car_Parts_Accessories&hash=item43afa06655#ht_2678wt_118
5
there's a f**k load of variations on ebay, i wanna make sure i'm not overseeing something before i order it.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
