Real interested to know if the original tune was by the same tuner ? If the before tune was by the same guy then that removes a variable of it being overly conservative
i assume so if they have the old data on hand, anthony does all the tuning down at Jaustech. from the owner:
"Before I put the tomei poncams an tomei gears in I was already running a z32, Walbro 500hp intank, gtr injectors, nistune, hypergear atr43ss1, blitz highflowed 3inch turbo back zorst, fmic. That's almost everything I can think of atm.
Results really depend on how big the cams are, these drop in and are built to respond in the mid range more than bigger cams. Big cams will be sluggish but have lots of topend so not real good for a streeter. These would be as big as I'd go, you want response for a quick car and this is a good example! Just went through adleaide hills last night, very quick!"
it doesn't tell you much, but that was in response to me asking if anything else had been done between dyno's.
i'm thinking the same, i have them sitting there, and although i've had a few bites i think i'd rather just chuck them in for now and see what they do, worst comes to worse i can rip them out later.
although at the same time tempted to just sit back and watch you put them in first haha
hey guys, just to confirm, this is the one i'm after yeh?
http://www.ebay.com.au/itm/Kinugawa-Turbocharger-3-TD06SL2-20G-w-T3-8cm-V-Band-Hsg-No-Anti-Surge-Inlet-/290709333589?pt=AU_Car_Parts_Accessories&hash=item43afa06655#ht_2678wt_118
5
there's a f**k load of variations on ebay, i wanna make sure i'm not overseeing something before i order it.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
