Need some help guys,
Im putting my old mans car back together, he was rebuilding the engine with my older brother, he passed away 3 months ago and he never got to finish putting the car back together, i've taken it over, have the engine back together and in, I found the fuel pump was u/s, so we pulled that out, in the process we saw the float floating on the top of the fuel, so if anyone has any idea where this is supposed to be secured? second thing is, does anyone know were to purchase the fuel tank seal on the top of the tank?
There will be an "arm" that the float is supposed to be attachted to. . . when i had this problem i just swapped in another fuel pump/cradle assembly as i couldnt confidently resecure to float and rely on it to stay put
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
