G'Day
I am parting out my track 32 gtr
Complete front end, bonnet, guards, front bar, lip and reo. It is off a track car so has bonnet pin holes a few small dents in the guards and a slot cut in the front bar. Still looks tough $1,000.00
Big exhaust $80.00
Front pipe $80.00
Crs Dumps $280.00
Cusco gear has been on the car for 5 lap of Malalla
Cusco Front sway bay $200.00
Cusco front negative camber upper arms -5mm $250.00
Cusco adjustable bar that goes between the castor rod mounts $100.00
Cusco rear sway bar $200.00
Not cusco front strut brace $80.00
Front drive shafts reconed at OG CV joints (no play) $90.00 each
R34 GTR turbos $350.00
6 Point cams approved with paperwork bolt in cage with side intrusion bars - made by Nick from Buddy Parts $1,800.00
What sizes are your sway bars?
Also, are the headlights genuine N1's with moulded plastic clips or are they the GTS-t version with metal clips for the grill?
Info from the order the front is 24mm and the rear is 30mm. Google the Part No. for full description *** They are hollow ***
> 1x 231 479 AC Cusco FRONT Negative Camber Upper Arms -5mm for BNR32
> 1x 231 311 A Cusco FRONT Sway bar for BNR32
> 1x 231 311 B Cusco REAR Sway bar for BNR32
1x 231 485 A Cusco Tension Rod Bar for BNR32
The headlights are not in the $1000.00 but they are for sale, I will investigate the clips tonight.
Cusco goodness with mint driveshafts
CES Dumps good quality locally made dumps
Don't know what make it is but it is 93mm in Diameter
R34 Turbos
post-41741-0-08730900-1338374025_thumb.jpegpost-41741-0-26818700-1338374045_thumb.jpeg
I have drilled a couple of holes in the guards to cable tie the front bar on and they have been rolled.
how did your car handle with all this cusco goodness? over steer / under steer etc.
It was better than the stock bars as I was running slicks and they made it lean a fair bit. I can't really comment on the balance as I only ran 5 laps, but I assume some cusco propeller head would have made them match.
How much would you sell front bar for? also whats the condition, dents, chips ect.. cheers bud
$200 with the reo and lip, It needs work / paint and I have cut a slot in it for the tow loop.
Tried to PM, but you must be full.
Would you be interested in parting out the grill?
Thanks
Yep $100.00 I also have the original mesh $50.00
More Cusco goodness.
I have had a look at the front guards and they are a bit rough so $250 for the pair.
Bonnet $300.00
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
