I had an issue where when I was cruising for some distance my tune was running rich and fouling plugs. Around town was fine but any highway use it was playing up next day on cold start. I backed the map off only slightly on that fuel cell and it has fixed the problem. Just thought i would mention that sounds it could be the same
  • Replies 51
Definitely a possibility, if I was to pull the plugs after a failed idle when I start it how could I tell if they are fouled easily?
Actually the only times the car idled well was when we first put the injectors in, then it went to shit, and then I changed the plugs before the tune and it was shit after that, then came good for a week then went shit again.
Maybe they have just fouled up badly.
Edited by Rolls
Is ur fuel pressure stable? Ie has the pump been rewired to battery voltage?
Is 02 feedback enabled?
If u have the software or consult keep a close eye on inj duty when idle is good and when idle is playing up. Let me know the readings
Fuel pump is new and rewired to battery voltage, O2 feedback is enabled as well, just need to borrow a laptop so I can run consult again.
Does anyone know what the "Fuel Dumper" is? as I did not get this part when I bought my fuel rail, is it a dampener of some sort? Perhaps this could be my issue.
Seems like a misfire when cold, cannot figure out why though, really need to get a wideband in the exhaust to see if it is going lean/rich or if it is super rich at idle fouling the plugs.
Bummer because I have neither a wideband, nor a nistune license.
Hey, that's awesome. The country I am in cannot be typed in spelled correctly, because it gets replaced with what you see in my post above. Just for the fun of it, the country I am in is bordered by Greece, Albania, Syria, Iraq, Iran and Armenia, with coasts on the Black, Adriatic and Agean Seas.
And in some respects it is the sphinter of the universe!! Although I don't mind it. Sphincters are not all bad.
Am trying to make the kiln burner here work properly. I designed it last year, installed in February, and it hasn't worked properly since. Has in fact made the whole plant worse. It's my fault and it's not my fault. Bloody plant has huge issues. Given the huge issues I should have called the whole thing off instead of proceding. But I let optimism strike me, went ahead with it, optimism bailed on the deal and left me with a handful of poo. The goat lovers are also not very able to handle the subtleties of a carefully written performance guarantee, and refuse to accept that given that the plant is poo, it is not entirely my fault that my burner made it smell worse.
Rolls my idle sounds very similar to yours.
I idle at around 1400-1500 when cold and it hunts randomly and sits there missing until warm.
Once warm idle drops to around 700 and them every now and then hunts but does not miss.
If you take it for a drive when cold
As you take your foot off and coast you can feel it missing.
All goes away when warm
Hmm this morning it was much much better, I didn't drive the car yesterday at all so it must have been completely stone cold, still did a slight miss for 3 seconds then come good for 3 seconds but it didn't want to stall, just went from 1300rpm to 1000-1100rpm.
Tonight it was back shit again wanting to stall from 1300 to 400rpm.
I have my laptop back so I will plug in consult and do a dump of injectors/afm etc vs rpm when its cold see if it is an ECU or mechanical problem, I personally think it is fouling the plugs up from possibly too rich an idle.
Ok did a log when cold, when at 1200rpm the duty cycle is 1-2 and pulse width is 2.2ms, when it stumbles duty is 1 and pulse width grows to 2.5ms all the way to 3ms when it starts missing badly, timing changes from 30 to 34 when stumbling, acc duty increases slightly.
Stab the throttle and it goes back to 1200 and duty at 2, pulse at 2.2ms, starts to stumble and go up to 2.8ms etc.
Would this be as simple as just changing the cold start enrichment at 20-30c so it is slightly less rich? I'm going to buy a license next month so will have a fiddle then.
So I am guessing the cold start is just simply too rich
Edited by Rolls
Its possible. Bust never assume its too rich without having a wideband to tell u afr.
The timing doesn't seem right. It should not be at 30 degree's at idle. That tells me ur tps may not be setup correctly. Try dropping the tps back a tad ie: if its at .5 try .46
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
