  • Replies 51
We adjusted the trigger voltage to 1.0v I believe, you can confirm by the "closed throttle" being at 1 and when I touch the throttle and it goes above 1v it goes to 0
When we adjusted the trigger voltage below this it would just rev and hunt weirdly, I am positive it is in the idle mode when the throttle is closed as it isn't doing this.
Edited by Rolls
Ok thats fine as long as its in the idle mode.u must be running an rb20 ecu if u can adjust the tps trigger voltage via ecu.
There may be something else causing it to go out of idle mode to make it run 30degree's timing. But try adjusting the tps anyway. Theres 2 small screws u need to loosen slightly then rotate the tps. Have the key on and use the consult. Adjust the tps to .7 if its at .8 now.
Have a play around and monitor if the idle stays stable
Ok today the idle was great again, started first go, no pops then after about 10 seconds would get an ever so slightly mild pop, idled great the entire way to work.
log says ~1100rpm+-20rpm so stable, water temp was about 20c, tps 0.88, 30 degrees timing, 2.08-2.11ms injector, O2 still reading lean. After about a minute idle dropped to ~900 and timing dropped down 1 degree at a time to 26 degrees eventually to 15 degrees when warm.
The only difference between today and yesterday is it is much colder this morning and I left the car outside, the other thing is I drove straight home without really getting over 60 last night. It is possible the plugs are just fouling up on boost maybe?
Can try playing with the TPS but I think it is something else, it just doesn't make a whole lot of sense to go from almost undriveable to perfect over night and then back again.
Edited by Rolls
Its definately a weird issue as its intermittant. Best bet would be get a wideband on it. Check it at idle. My guess is its leaning out causing a lean pop.
Ive had similar issue's with a z32 rb25 NIStune. Idle afr would be stable then every minute or so would lean out and start popping. I left the 02 sensor off(which i normally do anyway) but turned on the 02 flags around idle which stabilised the afr's. I spoke to Matt about this and he was goong to check it out for me
I have had weird idle issues before with my idle going as lean as 17-18:1 when hot, but then dropping back down to 14:1 randomly.
The fact that the O2 sensor says it is lean at cold start idle vs rich when warm could be evidence of that, wish I knew someone with a wideband as it is a pain in the ass to drop it somewhere just to check the cold idle.
How reliable is the rich/lean condition of the O2 sensor, should it be lean at idle? You'd think when cold it would want a rich idle to be stable.
Edited by Rolls
I don't think the O2 feedback works when cold, I've unplugged the O2 sensor and there is no change to idle until warm.
The O2 does seem to work though, if you give it a rev it flicks over to rich.
Edited by Rolls
  • 1 month later...
Got it fixed, was a coupled of problems, a) the AAC was seized and not responding, put a new one on and it made the idle more stable, but still was stumbling and doing weird shit. Eventually got it nice by just playing with the injector latency settings and then tweaking the mixtures down low, took them forever as it was very fiddly and just didn't want to idle nicely but now its pretty good, still pops occasionally but it is stable at ~750, doesn't hunt and comes back to idle nicely if you are on boost then immediately clutch in.
I am not confident the problem has been fixed though, I just think it has been masked, as occasionally when driving it will stop the occasional pop and get even smoother and never pop, still I don't really care anymore as long as I can do skids and chirp 2nd.
  • 8 months later...
Possible AFM issue? Do you have the NisTune software? Most sensors/acc etc. can be monitored on the consult panel. You'd think a cold log would detect a sensor issue. Particularly if it comes good once warm.
do you think its the same issue im having a seized valve (maybe from sitting around for so long)
http://www.skylinesaustralia.com/forums/topic/423722-another-idle-hunt-issue/
please read my post
Thread resurrection!
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
