Hey guys,
So I have purchased my dream wheels for my S2 R33 GTST recently and although it looks great and all, it isn't really fun to drive in mainly because the tyres hit against the guards when going over big speed bumps. The problem becomes worst when I have a passenger in the rear (let alone a full car load).
My wheels are 17 x 9 +22 (I'm running 255/40 tyres at the front and 245/45 at the rear). The car has been lowered on cusco coilovers and the damper settings is currently on 4 out of the max 5. I do not want to invest in a camber kit/bushes (maybe in the future when I have more funds) so I am looking for a cheaper solution. I do not want to run stretched tyres.
I initially thought my guards were rolled but have since been told otherwise. Can someone please tell me if my guards has been rolled or not by referring to the pics below?
If they have been rolled - Will flaring of the guards solve the problem and how much flaring will I need
If they are not rolled - Will rolling the guards solve the problem or do I still need to get them flared abit
Any other solutions I havn't thought of?
Thanks for your help guys!!!
Edited by newbatplay
https://www.sau.com.au/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/
Thanks Aaron
The two picture of the guards was at the front. The rears are exactly the same. I thought unrolled guards sit L shape whereas mine appear to be pressed together?
So the plastic inner guards are just the black plastic thing held by that bolt? Will water/dirt likely to cause me more problems?
I'm located in Sydney.
yeh dirt kind of gets into annoying places only really gets in front of the door jam.. just hard to clean.. you can try trimming perhaps.. if you in melbourne i can re roll them or flare it if you need..
the fronts have the tabs still straight. they arent rolled.
wow thanks for your kind offer! =)
When you say the tabs are still straight, do you mean like an 'L' shape? Because mine are more like a V if you get what I mean.....
why do you have 255 on the front and 245 on the rear???
245 on front and 255 on rear will have less clearance issues surely?
are they 17x9 +22 all front and rear, cause it looks like a good offset and size to have on a gtst..
I know 17x9 +38 dont fit on the front comfortably with 255 tyres
I initally had 255 at the rear and 245 at the front but the front tyres would hit the guards going over smallish bumps so I switched them around. Most probably due to the height (245/45 has a wall height of 110mm compared to 255/40 with a wall height of 102mm).
They are 17x9+22 all around and IMO they are the perfect specs for a R33 GTST if you can get them to fit.
I bought the wheels with the tyres. 235/40/17 or a slightly stretched 225/45/17 wouldve been perfect
17x9+38 compared to 17x9+22 would retract the wheel from the outer edge by 16mm. When you say they don't fit, is it because it will hit the inner strut?
It looks like my guards have been rolled but wasn't rolled properly. This thread <http://www.ozmpsclub...-all-equal.html> indicates that there are 2 types of guard rolls. Flatten the lip entirely vs. conventional roll.
It may be the case that I need a complete wheel arch (flattening the lip) roll to stop the scrapping as described in the link.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
