  • 5 weeks later...
  • Replies 91
So after installing the boost controller it was time to test it out on the dyno.
sorry the pics are a bit shity but here we go.
We tryed 3 diferent settings,(stock turbo is f**ked) 7psi,9psi and 10.5psi droping off to around 9 leaving it at 170kw.
Sadly it was pig rich,stupid stock ecu, so theres an easy 10-15kwto be had if it was runing around 12.5:1
but ended up with a 14% gain overall.
KW and Torque
KW and boost
Torque and boost
Since we have turned the boost up on the R34 it was time for a front mount intercooler
I was pretty surprised how much bigger the GTT intercooler is compared to an R33 one
Delta fin 8-) tested on of these coolers on my mates rb25 s13 on the dyno against another type of intercooler and it really performed well,
much lower intake temps.
will probly finish it on tuesday
Hmmm i started having a problem with the r32 idleing really high, and it seemed like the throttlebody's were not fully closing.
After checking everything that could be affecting the last thing to do was remove the intake manifold,and im glad i did....
Pulling the plenum away from the throttle bodys i strait away saw the peice of tissue paper caught around one of the throttlebodys,dope au
So i thought f**k while this shits off i might aswell do as much as i can so i decided to get rid of evrey single water line, heater hoses and all,everythings gone, getting rid of some realy shit hoses andd a million possible leak points
And i also gave the plenum a blasting while its off to
As soon as i get some ball joints and swaybar bushes this will be going in the laurel
Thanks DJRIFT, yea its definantly a problem, my tuner had a considerable voltage drop in his 32 GTR through shitty old loom,
So he wasnt going to tune mine until i had done it haha.
:thumbsup: Cheer's Samos69, haha yea well my mate had a GTS-t the same year and the rego just said "skyline coupe" so we threw the rego and plates on
the GTR, i drove it all the way from Auckland to New plymouth :sweat: 260km runs on the motorway
Trying to build a responsive 20 :P
Its a Garrett copy T28, watercooled, 360* thrust bearing and .64 rear, should be good for the rb20, even a shity t3t4 makes 20's pretty damn laggy, so this shud be good.
Yea its a t3-t2 adaptor and im going to have the wastegate venting from it, much easier than moding the manifold, and it means i get
to keep the heat sheild ;)
I saw a picture of a cef a little while ago with one, and that was runing a huge turbo to, so im hoping it will fit fine in the laurel (finger's crossed)
Just palnning on runing it on around 13-14psi runing a mines chiped ecu, would be happy if it made 160-170kw,injectors would be maxed tho.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
