Hi guys.
I'm looking to buy some Dzus fasteners to fix panels, under trays and diffusers etc to my car for quick removal.
Can anyone recommend where to buy from? Seem expensive in some places. Tried eBay too. but unclear on how they attach to the fixed part.
I want the self ejecting type on this website.
http://www.performancewholesale.com.au/component/content/article/305-dzus-part-numbers?catid=57#selfeject
I'm a bit unclear on how they attach to the fixed part. Any advice or guidance.
thanks
Russ
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/
these things can be a bit of a pain, especially for things which are on and off regularly. They can get sloppy and misaligned.
There are other types of clips, or even consider bonnet pins for ease of use
I completely agree......
If you're looking at these for undertrays or flat floor sections I'd consider again Russ.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6387914
These are awesome for certain things, such as bodywork etc that comes on and off fairly often. Definitely wouldn't use them on parts that are excessively heavy or may take a hit, like a floor or undertray though.
Major negative in my opinion is that they aren't very tolerant of misalignment. If you want them to much locating of the part, there are better options.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6392660
  • 4 weeks later...
All of the turbine helicopters use these for most of the exterior panels that aren't structural. You can buy the in some fairly large sizes and I haven't ever seen any fail that haven't been miss installed (wrong length or old/over tightened and broke the tangs).
If it has to take load I'd run nut plates and countersunk screws with a reinforced section in the removable panel. Might take 20 seconds longer for 6-10 screws to remove but for piece of mind. Buy an electric screwdriver and its the same time.
Also note that nutplates are way stronger than rivnuts without the issues as there steel not aluminium.
A few places on the airport sell dzus fittings in different sizes and styles.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6431335
Could try Camlocks too, often used in aviation where the breeze would be something approaching LMP speed on the Mulsanne.
Pretty much all methods mentioned, require reasonably accurate hole location.....although you can get floating nut plates that give extra wiggle room. Wicks and Aircraft Spruce - among others, do have handy little duplicating devices and templates which can save a bit of potty mouth during the fabrication.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6433880
  • 1 month later...
Dzus Fasteners? I work with them everyday. they are okay when new but after a bit of use.... they are designed to save time and to make sure stuff isnt overtorqued but after a bit of use they are just dumb. usually-well mannered people start using swear words and even invent some, and to be honest, they are pricey. Use the money on a good snap-on electric screwdriver, get some anchor nuts (nylock type) and forget these stupid things.
https://www.sau.com.au/forums/topic/401940-dzus-fasteners/#findComment-6505819
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
