  • Replies 77
  • 4 months later...
i recently purchased the tarzan g box off jesse streeter, will be here early april hopefully. Il try write up some feedback after instalation
Dragging this up. By any chance have you fitted and tested the Tarzan G sensor as yet. Keen to hear of your personal experience.
Read all there is on the net. Mostly PR stuff. But stumbled across 1 good rave by a GTR owner.
The new ETS Pro appears to replace the Gsensor with a similar MEM ?
In 2 minds :wacko::wacko:
I've had a Tarzan box in my car since mid last year.
The car has a LOT more traction coming off the corner, where I had to feed in the power before I can now be very aggressive with the throttle and the car just tracks out of the corner like its on rails (I know, hackneyed cliché but that is the best way to describe it). There is maybe a small difference to braking performance but I can't say its huge. ATESSA definitely responds faster and in a more decisive way.
Highly recommended.
Thanks for real world experience.
Tarzan G arrives next week for me.
As I own a 93 GTR I have an expectation any improvement will be a little greater than I have now, maybe closer to the later model GTR's (33/34).
You'll see a big difference.
The big thing about the Tarzan Box and the other replacement G-Sensors out there, (Midori & Do-Luck) is that the pendulum in oil OEM sensor will have degraded over the life of the car and will certainly not be working correctly. So any replacement will make the AWD work properly because it most certainly won't be if you have the original sensor installed.
I Tested the Tarzan G Sensor out this morning. (Seat of the pants testing). No track and no times.
A definite improvement and worth while :yes: even for the normal to spirited driving that I do :yes:. Doing track work then I believe the benefits would be even greater.
(I suppose so would a cheap Torque controller set to 7 on the dial?)
Cabin torque dial actually moving under acceleration off the lights :) and up through the gears. You feel it and you see it - Win!
It's progressive and reflects what your doing - depressing accelerator and it's shifting power to the front.
- rather than heavy acceleration and 4WD coming on late (unsettling car). I used to do this just to see if the Attessa is working.
Tested it out on a corner I take every day turning right on the large roundabout and then halfway round a quick left to get off it.
Normally I fight the car on the left turn from spearing off to the right. Not today :D went exactly where I pointed her.
My GTR feels more sure footed off the mark and around corners, especially accelerating out the other side. There is no just on or off it's more progressive / linear.
It's definitely more responsive making it feel like it has more power/grunt under acceleration from the getgo. Attessa (4wd) is definitely on ALOT quicker.
I am impatient and waiting, even a second or two longer, gives me the shits. (hence -7's)
Experiences may be different but for me a big improvement.
Before I am asked - YES my OEM G Sensor works as it was designed too - This G works ALOT better.
That's where I started too. Couldn't decide as there was no local/SAU feedback on the ETS Pro.
I went and bought the Tarzan G for now. and I'm very happy.
Post up if you go the ETS Pro - I'd be keen to hear.
Just doing a price round up as I previously mentioned my attessa unit is busted and I need a new one:
Tarzan G Box - $ 648.65 - http://www.nengun.com/do-luck/tarzan-g-box
Midori Digital - $ 560.48 - http://www.nengun.com/midori-seibi/midori-spec-digital-g-sensor
ETS Pro - $599 - http://www.full-race.com/store/r14-awd-skyline/ets-pro-center-diff-torque-split-controller-for-r32-r33-r34-skyline-gt-r-1.html
Am I missing any? Haven't found any more info on Ruzic's G Sensor replacement. Is there any difference between these three?
These are all 100% OEM replacements?
Attessa is busted or G sensor broken?
PM me if you want to just replace your G with another OEM G.
The Midori and Do Luck unit still appear pretty much the same to me with different outer casings and likely "tuned" slightly differently. (even the external wiring is the same)
ETS Pro, although programmable and can be auto or manual (the other 2 aren't). It is not 'plug n play' and does not interface directly with the ABS.
Although from what I read can be spliced in. ETS pro appears the goods for very serious track drivers.
Hence I took the easy out and went PnP.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
