Eoi:- Private Drag Day At Adelaide 1/4 Mile. July 1St 2012
sky30, mine is a 6mt zenki, HKS GTsupercharger kit,Bilstein coilovers, 275/40 R18 Advan Sports on the rear, the standard R200vLSD and a twin plate clutch that's hard to launch with! 234rwkw on the Willall dyno.
a stock 350Z/V35 is meant to do about 14.4 so i was predicting mid 13s for my first time out..
several reasons for performing worse than expected i think:
- inexperience at drag racing and quick launches
- not enough heat in the tyres due to my piddly burnouts
- traction issues off the line
- traction issues changing to 2nd
- being a retard and hitting the rev limiter a couple of times (i think this stems from 6 years of driving a type-r integra that you had to rev the SHIT out of)
i expected not to have as much issues with traction considering my comparatively small power and torque and decent sized street tyres. lesson to be learnt i think is that, like circuit driving, tires can make a HUGE difference!
pretty keen to see if i can improve on my pb around mallala (1:23.05 in my old 118fwkw type-r).
Edited by szymonsta
  • Replies 197
Posted Images
yes i have a run of u and him up loading now
he did a shocker of a launch on one run and it 4 wheeled hopped for like 10 mtrs ..................i felt the pain of the drive line lol
tyre pressure and a good burnout goes a long way. I was being a bit of a sook with my burnouts at first and not getting much traction, did a few high 13s. Dropped the tyre pressure and did a decent skid, made a 12.7. This is on 2+ year old 235/40/18
Jet, that's what i though too, clutch slipping, turns out it was wheel spin. Once we reduce the oil flow to the turbo I'll be ready to go again - should have it done by end of next week.
Thanks for the video, I'll check it out in a sec - think that was my 2nd pass when it turned the rears.
Yep, that's the second pass when it wouldnt grip, a low 113.7mph. It didn't help that the track officals noticed the previous car dropped fluid on the track and simply mopped it up with household mop! The next pass I ran 128.6mph.
No going to hold off till Sept or Oct, might go for a look though. A street meet after a comp meet is the go track should be well prepped.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
