I think the best i got from Amayama was around 4 days, i was surprised thats for sure :) No big ute full of parts delivered it though.............
Its me thats fat, not the helmet dude! Hahaha :laugh:
Yeah Commo drivers :spank:
The 34 is pretty big inside, i guess i never thought about the extra space for a helmet though.... I well, maybe i can drive commo spec like Benji and lay the seat back.... :P
I had bride lowered seat rails connected to an amazing Recaro but had to give it up too pay bills :dry:
And who you calling Raymond punk? :domokun: lol
Dude I thought your name was Raymond. Just realised it's actually Matt haha. I was reading the top line of the location part of your info thing without realising
And yeah, I do recline the commodore seat back and on its lowest setting for the "cant see over the dash" look. I've even started using words like "Brah" and "Aye".
When used in a sentence; "Yeah brah commy looks mad but im gonna dump it on its guts soon ayeee".
Doesn't work with RB stuff and Skylines
Onlly parts that can be overnighted from Japan are "2JZee no shiiiiit " parts
I wish I was able to afford a Toyota Supra RZ...the 2jz engine is an amazing feat of engineering. Supra is the ultimate highway/track monster.
Benji,
you need to put 20's on the front and stocks on the back to be a true bogan.
An don't forget the chev badge and to get a southern cross tatoo while your at it.
:no: :no: :no:
Edited by wedge_r34gtr
Yea probably, going to the knights game, will be most likely keen to have a few after more than likely watching them lose ha
Might end up at the exchange after the party if your going there
yeah i do too martin so will be a breeze
I'm going to ring you for a lift home then
BTW Where do you work that you start that early?
hahaha where do you live?? i wont have time to get you out to west newy, gotta meet matt in charlestown at 5 and gotta pick up chookie before that, or else i would because taxis suck balls in newy.
im a sparky, start work at 5 fridays and saturdays to leave at 130 and 1230, but when i do 12 hour shifts i also start early so i can leave at 530
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
