No idea sorry, they sit alright in the Gtr guards though. What rim is it?
I have a spare set of hks cam gears that I'll sell for a special newe price if anyone is interested.
Could be interested in the cam gears mate, it's the next bit on my list. Can you pm me some details please and can go from there?
Or could have a chat about it tonight if your going to the pub?
yeah chat tonight. There at Pauls place atm, but if his home this arvo i'll try and grab and take some photos. There both in excellent condition, except the anodising is fading slightly on the EX cam.
I picked up set of cheap tomei ones, so i'm going with them just to keep the tomei theme going on my head (poncams, retainers, springs etc).
So keen for tonight, work has been the worst and i only started an hour ago, f**k accounts payable, coordinators, and useless team members
this forum needs a like button
Sounds like some Lulz where had after I left
Good night good food and good company,will have to make sure the wife comes along next tiime
EDIT. Thread is up in the events section
Feel free to add/edit it as I can only use my phone at the moment
No Internet makes M.J.H something something
Edited by m.j.h
Wrong thread but maybe?
But nothing happening in here lately so might as well post the spotted cars as well
it was getting quiet in here thought people were dropping off their perches :P
Its the 3rd time in 2weeks ive seen the car, perhaps a stalker :P jks
Me and ant dog are at the snow having a lovely time till sat
Jelly!!!!!!!! :mellow: Have a good time guys!!!!!!!!!
Ill be back whoring up SAU in a couple of weeks, work is consuming me lately............................. :down:
last i saw of my GTR was on a tow truck on the way to Team K Kustoms for a full rebuild.....
This is whats going in her :D should be done by the end of this month then ill come up from the coast for a few meets
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
Stock/N1 oil pump
Reimax gears for oil pump
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Not a bad little setup - plenty of supporting mods for when the power bug hits :-)
Edited by wedge_r34gtr
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
