No idea sorry, they sit alright in the Gtr guards though. What rim is it?
I have a spare set of hks cam gears that I'll sell for a special newe price if anyone is interested.
Could be interested in the cam gears mate, it's the next bit on my list. Can you pm me some details please and can go from there?
Or could have a chat about it tonight if your going to the pub?
yeah chat tonight. There at Pauls place atm, but if his home this arvo i'll try and grab and take some photos. There both in excellent condition, except the anodising is fading slightly on the EX cam.
I picked up set of cheap tomei ones, so i'm going with them just to keep the tomei theme going on my head (poncams, retainers, springs etc).
So keen for tonight, work has been the worst and i only started an hour ago, f**k accounts payable, coordinators, and useless team members
this forum needs a like button
Sounds like some Lulz where had after I left
Good night good food and good company,will have to make sure the wife comes along next tiime
EDIT. Thread is up in the events section
Feel free to add/edit it as I can only use my phone at the moment
No Internet makes M.J.H something something
Edited by m.j.h
Wrong thread but maybe?
But nothing happening in here lately so might as well post the spotted cars as well
it was getting quiet in here thought people were dropping off their perches :P
Its the 3rd time in 2weeks ive seen the car, perhaps a stalker :P jks
Me and ant dog are at the snow having a lovely time till sat
Jelly!!!!!!!! :mellow: Have a good time guys!!!!!!!!!
Ill be back whoring up SAU in a couple of weeks, work is consuming me lately............................. :down:
last i saw of my GTR was on a tow truck on the way to Team K Kustoms for a full rebuild.....
This is whats going in her :D should be done by the end of this month then ill come up from the coast for a few meets
CP Pistons
Manly Turbo tough rods 1000hp
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
Tomei Oil restrictor
ACL bearings
studs
Tomei valve springs
Gates racing timeing belt kit
Gasket kit
Stock/N1 oil pump
Reimax gears for oil pump
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Not a bad little setup - plenty of supporting mods for when the power bug hits :-)
Edited by wedge_r34gtr
CP Pistons
Tomei Head gasket
Tomei Baffle pan
Mines Cam baffle
ACL bearings
studs
Tomei valve springs
Gasket kit
Stock/N1 oil pump
Sounds like a nice list of parts
What turbo/s you going to run?
Come along on the 26th anyway doesn't matter what car we will only be doing the speed limit anyway
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
