Martin picked it- there's an oil drain for a VCT setup in the sump. Want to do a bit of r&d next year for a VCT setup idea I've got.
Overnight parts from japan sounds good in the movies...what they don't mention is that there is a 6 week manufacturing lead time at the moment...
Also, theres still heaps of of fab work to do and I don't want to stress Paul out trying to get this complete.
Edited by wedge_r34gtr
Yeah don't rush it mate, not worth it.... It's looking awesome!
Did you run an external head drain thingy?
guys you dont need to go for the whole weekend for the nats, i think its the 18th, that weekend in nov.
mat whats actually involved in fixing my diff?? will i just need oil for it and a case of beer for you? or will there be other hidden costs??
pretty sure all i gotta do is fix my LSD, fit my oil cooler, get a few tanks of petrol and pay entry fee.
shouldnt cost to much.
Depends what u wanna do with the diff mate.... I think you should duck over and see Aaron at Difftrans and let him drive it etc.... If he needs it out to work on just bring it over and I'll take it out for ya :) don't worry about beer, happy to help....
IF my car isn't going for some reason I can put my diff in your car, OR we can get the spare one I have back together (it's nearly locked tho)
What's wrong with the diff?
And what's with all the broken cars ATM
nearly locked diff, ill give you 2 hugs and a hand shake for it :D
When you do the VCT you should mate it to an RD28 block setup as well
Would be a response monster
Edited by m.j.h
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
