That's awesome!
Just finished drinking at the sleeze breeze did you?
meet up for a social tonite?
sugarloaf?
Sounds Suss Tayden :P
Hey Guys, Alex is back for the weekend (working in QLD) so i am organising dinner at Billabongs just to catch up, Gaz is coming in the freshly sprayed S15 and Andrew is tagging along too.
https://plus.google.com/105555925212485235969/about?gl=au&hl=en
All you can eat buffet and the food is normally pretty decent... If you wanna tag along just let me know as ill need to make a booking :woot:
No Problem Jarrad, its nothing official but just a good excuse to catch up for an hour or two and enjoy a good feed :)
I was going anyway and Alex mentioned he wanted to meet you guys, so i thought i would kill 2 stones with 1 bird :P
my GTR still not fixed -_- pistons coming in from teh USA slowed it down still 2 weeks off b4 i can get out for anything.
We'll be waiting to see your beast ;)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
