I'm not a fan of stretch at all (but that rim had bugger all ant). My rule of thumb for the minimum is 255 for 9.5, 265 for 10 and 275 for 10.5.
Not a bad rule...
Yea neither really.
I don't want to push going wider though due to rubbing...
Yea neither really.
Rubbings racing.....
Wow, days of thunder, must watch again... Was the fast and furious of its time :D
Yea neither really.
yeah true. From memory, i think you can get away with 285 on 10.5 without dramas. A 34gtr lowered due to coilovers may not.
I think you can run 285 30s on 18s without too many drama, but 19s would be pushing it I think.
I wanna run 285's :(
Oh, and on a positive note (not for me as I'll wanna kill kunce) I am signing up for Ocsober... And u kunce have to Put up with me for a month with no beer.... It's not pretty but I'll do my best!
Greetings from budgiwoi guys. :action-smiley-069:
Hey hey, how you doing? Next cruise is booked for the 21st of next month, will you be around?
Oh, and for all you guys that know Jez -
http://www.skylinesaustralia.com/forums/topic/409610-happy-birthday-dvs-jez/page__fromsearch__1
Thought it would be a nice idea :D
Hmm I might be out for nats boys.
People have been losing jobs left right and centre at work because we haven't got any contracts after dec and they said today all 4th years that can be signed off early will be in nov. I'm guessing all that can't may be told cya later. I'm not sure if I'll be able to or not yet but should be ok.
But I don't think I'll get a job till after Xmas as everyone is telling me people to hire till mid-late Jan.
Thinking after I spend 1k at nats if something blows or I come off and break shit and I don't have income it could result badly.
Still haven't made up my mind yet, idk. Would be fun but I don't wanna blow an engine or something the. Have 1000 bucks to last the summer haha
http://www.skylinesa...__fromsearch__1
Hey matt,if i'm up here then in for sure. genelle.
You wont break the engine but you do have pads, clutch, tyres etc that will cop wear!!!
Just come down with us anyway if you want mate? Dont want you to miss out on a good thing....
Awesome! Will be good to see you again.....
Unless you going to Texi? Then i may see you there as i will be off the drink so no point sitting around and watching Bathurst without beer, would be Un-Strayan!
hmm i think im mainly worried about the clutch, the trsut bearing always makes a grinding noise for a month after a track day.
idk, it should be fine.
i got some uplifting news today after writing that post so i may still enter.
just gotta hope people will be hiring in november i guess or ill be applying for supercheap over summer hahaha
My clutch went all of a sudden so i dunno if yours has been done or not, but it will be probably the weak link? Trust me, i am a clutch killing expert!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
